Sponsored by: Real Truck
2004 F250 Brake Light Problems
Old Mar 10, 2012 | 09:12 PM
bibababy's Avatar
bibababy
Unhappy 2004 F250 Brake Light Problems
I have an F250 with brake lights that dont work. I have checked the fuses and they are ok. The cab brake light comes on but the exterior lights don't. The tail lights work. Please help.
Thanks
bibababy
Old Mar 11, 2012 | 06:10 AM
1973Ford2004's Avatar
1973Ford2004
Take a test light and check that you have power to brake light socket, if yes, then change the bulb, if no then start chasing the wires, I would start in the harness where your trailer towing pigtail is wired in, you could also check to see if you have brake power at the trailer plug. Good Luck.
romanelli
Feb 7, 2018 02:26 AM
benjaminkell
Jun 13, 2017 07:00 AM
GM4WALLS
Dec 12, 2015 08:21 AM
jonrjen
Electrical Systems/Wiring
Jul 6, 2010 08:38 AM
LARIAT 85
22
Oct 24, 2009 09:14 PM
