1978 - 1996 Big Bronco
push button 4x4
Old Apr 2, 2005 | 04:13 PM
PressureDrop's Avatar
PressureDrop
push button 4x4
my 95 Bronco has the push button 4x4 and low range on the dash and i hate it, im not sure which t-case it has, but i would assume they are all the same, so my question is, is there a kit that converts it to manual t-case (linkage, lever etc...) if someone could point me in the right dirrection i would appreciate it
and i would like to avoid junkyard parts
Thanks
Ben
Old Apr 2, 2005 | 04:39 PM
greystreak92's Avatar
greystreak92
You can swap the Borg-Warner 1356 electronic T-case in your truck for the manual version of the 1356 but you will need to do a complete swap. There is no way the alter the electronic version to work as a manual.
Old Apr 2, 2005 | 07:20 PM
93bronc84's Avatar
93bronc84
I researched it to the T and found it is a direct swap for the manual and there is even the factory cut hole under the carpet. all you need to do is pop off a glued in cover plate.
Old Apr 2, 2005 | 08:20 PM
greystreak92
Yep, the two cases are identical as far as bolt pattern and mounting but the case has two main castings that make up the external housing, a front and a rear. One of them (can't recall which right now) has the mounting for the electric shift motor OR the manual linkage. The casting for the manual is completely different from the casting for the electronic model so, unless you want to rip the electronic one apart, rebuild it (might as well if you tear it apart), and install the casting from a manual unit , its just easier to swap the whole T-case.
jayski
1997 - 2003 F150
15
May 1, 2021 06:45 PM
Millenium Edition
May 30, 2016 10:46 AM
Bubba Jones
Mar 31, 2016 10:28 AM
BigAl250
Mar 22, 2014 02:52 PM
Bigford4x4_83
Offroad & 4x4
Feb 18, 2004 06:00 AM
