1978 - 1996 Big Bronco
Tailgate Window Doesn't Work
Old Apr 1, 2005 | 08:12 PM
smolicht's Avatar
smolicht
The rear window on my 1989 bronco doesn't work. Tried replacing the motor with no help. Turns out that the motor works fine if I hook it up direct to the battery. I was going to replace the front and rear operating switches, but it turns out that they are no longer made. Any Ideas?? Thanks Tom
<!-- / message -->
Old Apr 1, 2005 | 08:19 PM
greystreak92's Avatar
greystreak92
Try these guys and check the circuit breakers that feed the two switches first. If they aren't resetting, you may only need to replace them. (They reset automatically once a short has been cleared).
Old Apr 2, 2005 | 09:31 AM
oldbluebronco's Avatar
oldbluebronco
Thumbs up Window
Try pushing the door in while you roll up the window. My dad's and my bronco both do that. something to do with the striker.
Old Apr 2, 2005 | 10:08 AM
351Inside's Avatar
351Inside
Try Wiring
I had the same trouble with my '96 and got together new/working switchs and while pulling out the key switch, realized I had a broken wire between the body and gate where the wires sort of twist when the gate moves. 18"
of new wire and 2" of shrinktube and "presto" - up and down ever since.
Old Apr 2, 2005 | 10:41 AM
1989bronco's Avatar
1989bronco
i got a new switch for my 89 at the local ford dealer. cost me $17
Old Apr 3, 2005 | 07:59 PM
Gurahl's Avatar
Gurahl
Hey try to replace the fuse. That's all it turned out to be with mine. Don't mean to make you sound like a twit, but i was.
