General Automotive Discussion
cracked tire sidewalls
Old Mar 19, 2005 | 07:01 PM
88grandmarquis's Avatar
88grandmarquis
I figured you folks could help me out.
This is regarding the front tires on my 1988 Mercury Grand Marquis which were purchased in May of 2003. There are less than 7,000 miles on the front tires and they are barely worn.
When I put my Cooper Cobras on today (took snow tires/rims off) I noticed that the front tires are cracked on the sidewall around the rim. Is this something I should be worried about? The cracks are quite noticeable.
Justin
Old Mar 19, 2005 | 07:09 PM
grease monkey's Avatar
grease monkey
When your tires have cracks on the side they are more prone for a blow out. I would personally replace the tire, I know that the cobras dont cost too much. Check you resiept because alot off places offer a tire warranty.
Old Mar 20, 2005 | 06:24 AM
fordman102's Avatar
fordman102
Only 2 years old! I wouldn't trust those tires. I'd go back to where you bought them and see if they have some kind of warranty. Like grease monkey said blow out on front tires very bad!!
Old Mar 20, 2005 | 08:45 AM
superrangerman2002's Avatar
superrangerman2002
Does the vehicle set outside a lot?
If so, those cracks are from sunlight. To keep it from happening you need to keep the tires covered to protect them from the sun if you can.
Old Mar 20, 2005 | 10:55 AM
88grandmarquis
The car is garaged most of the time and the tires are only run in the summer. They have only been used two summers.
I will be taking them back to the shop that I bought them from. New tires will be put on front.
Justin
Old Mar 21, 2005 | 11:20 AM
85e150's Avatar
85e150
How deep are the cracks? Superficial cracks are no big deal.
Also, while a front blowout is no picknic, most of the roll overs and problems both from the Firestone 500 days and the more recent Explorer issues were caused by rear tire blowouts. You can steer the front--not much you can do when the rear is pulling you all over the road.
Also, if you are replacing 2 tires you are better served with the best tires on the rear tread wise as well. Do you want the front end to give way first or the rear?
The answer is easy if you've ever had the back end come around on you when you weren't expecting it.
As for these 2 year old tires, hey, I'd try for the warranty also. There should be a number on them. Not sure if you can tell how old they are, as maybe they sat at the tire dealer for 2 or 3 years before you bought them.
Old Mar 21, 2005 | 11:38 AM
superrangerman2002
Have you been using a tire shine product of sorts? A lot of times this will cause the tire sidwalls to crack.
Old Mar 21, 2005 | 01:12 PM
DonsFx4's Avatar
DonsFx4
You can check the DOT code on the tire...the last 3 or 4 numbers are the date of manufacture.
3 number (ex 036) = first 2 digits are the week, last digit the year (ex is Jan 96)
4 number (ex 0301) = first 2 digits are week, last 2 digits the year (ex is Jan 01)
It's very possible they sat in a warehouse for some time before being installed on your car. Rubber will become brittle just by laying around, either in the warehouse or in storage in your garage. It needs to be run at operating temps to keep resiliency.
Old Mar 21, 2005 | 04:43 PM
88grandmarquis
I took the car down today. They are giving me a discount on the new tires.
The only tire shine product I've used on these tires it Mcquires (I'm pretty sure that's what is down in garage). I've only shined the tires three or four times in the two years.
Justin
Old Mar 21, 2005 | 06:40 PM
88grandmarquis
Here are a couple pics of the cracks.
Pic one
Pic two
Justin
Old Mar 21, 2005 | 08:16 PM
superrangerman2002
I'd say those are border line, but as new as they are, there's no excuse for this.
Kinda looks like the rubber compound was a bit on the dry side when they were manufactured, but that's purely speculation.
Old Mar 21, 2005 | 09:20 PM
Matts72's Avatar
Matts72
I've had lots of problems with Cooper tires... Lots of vibration, excessive wear, uneven wear...
Old Apr 12, 2005 | 10:10 PM
omni's Avatar
omni
I had a set of big country 31x10.5's that were cracked like that when I bought the truck, and I used them till they were worn out
ljutic ss
6.4L Power Stroke Diesel
Oct 10, 2013 06:06 PM
guitarpicr
Jul 10, 2011 08:33 AM
JCA433
2004 - 2008 F150
Aug 25, 2009 02:14 PM
mndiesel
Jul 28, 2008 02:26 PM
Mike W
Jun 3, 2002 01:02 PM
