Sponsored by: Kumho
tire sidewalls cracking
Old Jul 22, 2008 | 10:38 AM
mndiesel's Avatar
mndiesel
I just noticed that my Firestone tires (on truck when I bought it) have cracks in the sidewall. They look pretty deep and they are in the middle by the lettering. I know tires can do that if they sit for years but I have put 40k miles on them in 2 years (with rotatations). Any thoughts????
Old Jul 22, 2008 | 06:33 PM
Lou Braun's Avatar
Lou Braun
That cracking is usually due to UV damage from exposure to sunlight. Miles on the tire is not really a factor in this sort of damage. If the tires are significantly cracked, I'd replace them.
Other than keeping your truck parked out of direct sunlight there is little you can do to prevent UV damage. It is possible that a UV blocking coating (something like sun-tan lotion but for tires) would help. Maybe one of the popular tire dressings is also a UV blocker.
Lou Braun
Old Jul 22, 2008 | 08:16 PM
mndiesel's Avatar
mndiesel
thanks Lou I never would of thought that would effect it if they were being used so much but I believe it could
Old Jul 23, 2008 | 03:05 AM
aurgathor's Avatar
aurgathor
UV and ozone can do that. Check the date stamps on them.
Old Jul 27, 2008 | 10:38 AM
daddio360's Avatar
daddio360
I had Michelins LTX's that developed that affliction at about 5 years old but plenty of tread life left... I had a tire place look at them and they said they were very dangerous & should be replaced at once.
I don't know if It's because I'm cheap or crazy (or both) but I ran them until the tread was gone. To this day they are holding air. (Results may vary...I am by no means suggesting you should follow my example, but it worked for me.)
Old Jul 28, 2008 | 09:32 AM
mndiesel's Avatar
mndiesel
Thanks for the input. If I were only driving the truck I would probably chance it but I tow 12k lb 5th wheel a lot so I will replace them. Thanks for the info though.
Old Jul 28, 2008 | 02:26 PM
mark a.'s Avatar
mark a.
Most all tire shines will draw the UV protection right out of the rubber. Aero Space 303 will help but it sounds like it will be too late in your case.
Buckhorn2
Offroad & 4x4
Nov 4, 2013 11:32 PM
RA31925
All Things Towing
Oct 15, 2013 06:52 PM
ljutic ss
6.4L Power Stroke Diesel
Oct 10, 2013 06:06 PM
krol
Jul 19, 2005 10:38 PM
Mike W
Jun 3, 2002 01:02 PM
