Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Bending aluminum
Old Mar 15, 2005 | 06:33 PM
mark a.'s Avatar
mark a.
Bending aluminum
Is there any way to bend a 1" aluminum round bar in a pipe bender about 120 degrees to fit within a 10" space ?
Old Mar 15, 2005 | 06:44 PM
Superdave37076's Avatar
Superdave37076
What "kind" of aluminum and what is the end result to be used for?
SD
Old Mar 15, 2005 | 06:57 PM
mark a.'s Avatar
mark a.
I want to make a new light bar for on top of my roll bar, so it would be about 4 feet long with the ends bent around and down to the base. but I want more than 90 deg, just for looks. I havent bought any stock yet, wondering if it would be possible ?
Old Mar 15, 2005 | 10:45 PM
cigarxtc's Avatar
cigarxtc
Well, I haven't worked with aluminum bar that thick yet. I have recently used the 1/4inch aluminum stock that you can buy at Lowes Home improvement warehouses. It bends ok when cool or at room temperature. It bends even easier in the summer heat. I used a quality hand held tubing bender that can hand multiple sizes. The only problem I ran into was that cold bending weakened my pieces. If I tried to adjust a bend into another direction or straighten it back out my pieces would crack or break completely. The initial bends worked great at all angles, including making a complete circle. Also, there are many types of aluminum alloys. The type you get will dictate how well it responds to bending, heating, etc. Good luck, it sounds like a pretty cool idea!!!
Old Mar 15, 2005 | 10:48 PM
RocketScience's Avatar
RocketScience
Readily available aluminum bar will probably be 6061 T-6 Alloy. Depending on your bend radius, It may break if bent cold. To keep this from happening, you will need to anneal it, or soften it before you cold bend it. This would be typically done with an Oxy/acetylene torch in your situation. If you do not have this, a propane torch will work, but take four times as long. Heat up the area to be bent until it will lightly burn a piece of softwood (this is typically done using a heat crayon, but I'm going to assume you don't have one). This will be at about the right temperature to anneal the aluminum. Keep your torch moving in a back and forth motion, heating the area uniformly, and constantly checking the temp with your piece of wood. Once heated, cool the parts off with water. You are now ready to cold bend them.
Hint/Disclaimer:
Try a small scrap piece(s) first to perfect your technique.
Good luck!
Old Mar 15, 2005 | 11:53 PM
Superdave37076
Wink
Would there be a problem with using tubing instead of solid? If so, you might look at some of the stuff used on boats. The tubing would be stronger in mass to weight. Just a thought.
Old Mar 16, 2005 | 12:15 AM
mark a.'s Avatar
mark a.
I hadn't considered tubing because of the degree of the bend. I thought it would end up going flat. I suppose I could try filling it with sand ? if solid doesn't work.
Old Mar 16, 2005 | 01:17 AM
mark a.'s Avatar
mark a.
reply
Hint/Disclaimer:
Good luck!
What degree of crayon would you recomend ? and will there be any suprise when I touch the tig to it ? will I be wanting to stay down on the mounting bracket with the tig torch because it wasn't heated ? I guess what im asking is will it be like trying to weld 2 dissimilar metals after annealing the rod ?
Old Mar 16, 2005 | 02:30 AM
Ford_Six's Avatar
Ford_Six
You want about 350*, and it shouldn't give any surprises when welding. Just make sure to keep you interpass temp under 350*.
As far as the cooldown, try two scrap pieces first, one cooled in water, and the second air cooled naturally. The water cooled one may become brittle due to being cooled to fast.
Aluminum pipe doesn't like to be sand bent, it tends to split on the outside rather than draw and stretch like steel.
Old Mar 16, 2005 | 08:06 AM
mark a.'s Avatar
mark a.
Thanks for the replies, guess now I got to get my material and try it.
Old Mar 16, 2005 | 05:43 PM
RocketScience
Thanks Ford_Six for quantifying that one for me (I was gonna say 300* or so)
....and will there be any suprise when I touch the tig to it
Your only surprise may be with the amperage of your TIG welding machine (assuming you are a decent TIG welder). 1" dia. solid aluminum rod is right at the limit for a 150-175 Amp. (220V) machine. No problem with a 250-350 Amp. (440V.) machine. If you're stuck using a 150-175 Amp. machine, your gonna have to pre-heat (with a torch) your parts first, again 300 to 350 degrees - no big deal though, you should be fine.
Old Mar 16, 2005 | 08:34 PM
66fdtrucknut's Avatar
66fdtrucknut
What kind of pipe bender do you have? I use a enerpac at work for pipe and I don't think I could get 120 deg. w/schedule 40 dies. For tube I use a Hossfeld bender with tube dies and can bend >180 deg. You could use 3/4 in. pipe which meas. approx. 1 1/16 OD. I agree 6061 could break. I use alot of Annodized 6063 Alum. doing marine fabrication and never have a problem with it. Good luck with your project.
MCDavis
2004 - 2008 F150
45
Oct 18, 2010 01:35 PM
scrapyardking
General Automotive Discussion
Feb 8, 2008 10:02 PM
chrono4
Garage & Workshop
Oct 23, 2006 11:11 AM
holland501
Jul 21, 2004 09:44 AM
