Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
bending cast aluminum
Old Oct 17, 2006 | 08:29 PM
chrono4's Avatar
chrono4
At work weve got a a mold that somehow got bent pretty good. Its a lip about an inch thick, and twisted down. We need to bend it back up, but wastnt sure how to do it best. Heat it, press it, hit it, or what?
Old Oct 18, 2006 | 09:11 AM
Fully_Loaded's Avatar
Fully_Loaded
If you heat it and hit it it will damage it. I would heat cautiously and very carefully try and bend it with a pipe wrench but there is no promises that it will work. Cast, in my opinion, is chaep and flemsey.
Old Oct 18, 2006 | 10:11 AM
alchymist's Avatar
alchymist
"Mifflin Clay"
It is very difficult to use the words bend and cast in the same sentence.
Unless you're fishing, that is.
Old Oct 18, 2006 | 12:07 PM
lenny1carl's Avatar
lenny1carl
don't know how fast you need the answer, my step-son will be here at 5pm and is an alum expert(works w/it for yrs) i'll show him your ?? and get back asap
Old Oct 18, 2006 | 07:40 PM
chrono4's Avatar
chrono4
Fully loaded, I wouldnt call a 60 000 dollar mold cheap, lol. lenny, that would be great if you could. Thanks.
Old Oct 18, 2006 | 08:56 PM
Franken-Truck's Avatar
Franken-Truck
Cast aluminum. . .the stuff I'm experienced (term used loosely, lol) with doesn't really bend back. Once it "bends" it develops micro fractures where the side being bent away from is stretched and the aluminum literally tears.
I would, but this is just me. . .
-bend it back cold, grind out a portion of the upper area where it bent and weld it full. Then grind out a portion of the lower area and fill it with weld. machine if necessary.
- knock it off, clean it up and weld it back on and machine if necessary.
-Knock it off, and build it back up with aluminum weld and machine it.
Thats just my experience, mostly with outboard motor mounts and brackets
Old Oct 19, 2006 | 05:46 AM
lenny1carl's Avatar
lenny1carl
my son said almost as a quote what franken-truck said...wish i had better advice
Old Oct 23, 2006 | 11:11 AM
FarmLaw's Avatar
FarmLaw
Isn't there a way to soften it and allow bending by using a carbuerizing flame (heavy actylene)? Or is that on a different form of aluminum?
bigal53021
Dec 28, 2024 10:02 PM
burnthelight88
Aug 3, 2015 07:22 PM
SuperDuty93
13
Jan 6, 2014 01:23 AM
Epd444
Dec 21, 2008 06:08 PM
cigarxtc
Paint & Bodywork
May 2, 2003 09:34 AM
