General Automotive Discussion
Aluminum rollback beds ?
Old Feb 8, 2008 | 12:16 AM
scrapyardking's Avatar
scrapyardking
Looking to replace the bed on my truck due to some rust issues and was looking into an aluminum bed. But several old timers told me to stay away from aluminum beds because they tend to twist and bend easy.
So does anyone have any experience with these?
Should I stay with steal or go to aluminum?
Old Feb 8, 2008 | 12:41 AM
85e150's Avatar
85e150
If you can, steal one.
But if you have to buy,
Steel and aluminum:
http://www.jerr-dan.com/carriers/index.asp
I see a lot of these in aluminum, usually on F450 hauling cars, suvs, my e150...
These folks make 'em too:
http://www.godwingrouponline.com/
The aluminum ones I've seen wiggle and flex, but they seem to hold up.
Old Feb 8, 2008 | 10:03 AM
NJF350SD's Avatar
NJF350SD
It all depends what they are used for. Standard auto transport they seem to hold up fine. If they are used for recovery operations (especially off angle winching) or heavy vehicle towing (loaded pick-up trucks, etc.) , I would highly reccomend going with a steel bed.
Old Feb 8, 2008 | 10:34 AM
blue beast's Avatar
blue beast
If the support structure is good just have new metal put down and get the same
thicness as original or you will just add weight. A couple zinc anodes in the low
spots will help to prevent rust from standing water, not to mention if it is a tilt
bed or dump body parking so the front wheels are higher and the water can run
off will help. Do not leave them things raised it is a giant trap for knuckle heads
and a lawsuit waiting to happen!! Not to mention it can rust your cylinder.
Old Feb 8, 2008 | 12:52 PM
rebocardo's Avatar
rebocardo
Steel is much cheaper and much heavier.
A nice aluminum bed of 1/4" plate is very sturdy ... and very expensive.
The bad part of aluminum is you need a very good welder to repair it or to add things onto it vs. almost anyone can weld a steel deck and add hooks and hold downs with an ARC or MIG welder.
For your 1972 flatbed, I would go steel. The reason being is you will not benefit from any weight savings with increased MPG. A nice aluminum flatbed will not add to its resale value. So, going sturdy and cheap is what I would do.
Old Feb 8, 2008 | 05:15 PM
scrapyardking
Yea I will probably stay with steel
Old Feb 8, 2008 | 10:02 PM
monckywrench's Avatar
monckywrench
Heavy use, especially scrapping, can crack aluminum rollback beds. I've seen a few that the rail separated partially from the deck.
Want professional towing and equipment info/discussion?
Check Tow411:
http://tow411.yuku.com/
MeanGene1
2015 - 2020 F150
27
Aug 14, 2017 10:20 PM
F350NH11
Aug 6, 2017 04:35 PM
SatinBlack03
Jan 7, 2017 04:57 PM
cranegy
New Member Introductions
Oct 27, 2016 08:14 AM
hammer65
2009 - 2014 F150
Oct 24, 2016 05:31 AM
