Why has Ford had so many diffrent V8's
I've never seen this question asked before and I wonder what yall's opinion on this is. I've noticed that unlike other manufacturers Ford has had over a half dozen completely diffrent v8 engine degsins since the 50's....Why?, Were the engineers at Ford just bored or sumpin?
All manufacturers have had different motor designs.......The SBC's and GM's very intelligent interchangability have made them somewhat of an icon. But let's not forget the fact that when even considering GM, all the divisions had different motors that shared displacement. The Chevy 454 has nothing in common with an Olds or Pontiac 455........Chevy 400 is totally different than Pontiac 400 or Olds 403. ALL the divisions' 350's were propriatary at one time. Compared to Ford, GM had waaaay more "different" V8's.
(didn't even throw in the different Buick V8's in that fray)
Ford's weird practice of changing things.......sometimes in midyear....is more bizzare to me than the different engine families.
Let's compare the different makes/motors;
Chevy had a "W" motor(?) that I think was a 409
Ford's Y block was replaced by the FE's to compete.
Chevy came up with canted valve "Mark" series that included 396's, 402's, 427's, 454's and the current 496.........the 502 is also included but was never in a production car.
Ford's answer was the different variations of the FE and then the "385" series which included the 429/460 and 370's in medium trucks.
The small block Chevy was aprox 7 YEARS ahead of the small Ford motors. But both had unbelievably long runs.
Ford had the KING of small motors with the Cleveland but like Big stated, emissions and crappy fuel killed the big headed small block Ford.
The 351m/400 were supposed to be a stop gap to hopefully phase out the 385 series but also the Windsors. We know how that worked out.
Chevy came out with an LT1 version which was heavily based on the original SBC but is a different motor with little interchangability.
Chevy has the new from the ground up LS series of motors which share NOTHING with ANY previous SBC except for bore spacing.....let's throw in a short lived LT-5 DOHC Chevy 350 made by Lotus as another "different" V8.
Ford has had the MOD motors since the early 90's
A quick synopsis of this novel is Ford has barely any more different V8's than Chevy and waaaaaaay less different engine families than GM.
[edit] I'm sure there were a few motor families I left out (like the MEL series from Ford) but the point remains the same.
DOHCmarauder is correct. Ford, MOPAR and other manufacturers usually had a family of engines that were used in all of their products and interchanging them was not a proboem but GM had a different engine family for each of their line of cars and they couldn't be interchanged. Buick, Chevrolet, Pontiac, Oldsmobile, Cadillac and the trucks all had different V8 engines and many were the about the same size. GM got away from this in the late 70s when they had to pay out millions of dollars when they ran out of Oldsmobile 350 engines and used Chevrolet 350s instead and "forgot" to tell anyone. It was during one of our fuel shortages and the Oldsmobile engine had a higher fuel mileage rating and people sued. That was about the time GM converted the 350 to a diesel and we all know how that worked out.
I think it's just a higher standard of engineering. They wern't trying to make a one size fits all motor. They don't have a jack of all trades and a master of none motor. For the most part, each motor design is specialized to the apllication it's designed for.
For example, rather than just sticking the canted valve head on a 351w (that was already optimized for tourqey truck/large car use) they desinged a whole new motor around the head, so the head could perform it's best.
The Y block superceded the flat head, but it had to be replaced because it wasn't space and weight effcient enough by the end of the 50's. It weighed 610 lb's and could only support around 300 cubes.
The SBF is a master piece in space and weight effciency. It's one of the very best engineered engines you will ever find. Everything is smaller, lighter, and more compact. I can't think of more successful motor in racing history overall.
Rather than just stroke the 302 they came out with the 351w, so that correct engineering principles could be retained.
The FE is smaller and lighter than other engines of large displacement of the 50's and 60's, particularly considering it's extra stout structural integrity, but it's not really a big block in the same sense as the BBC or the B-RB.
The 385 is Ford's only true automotive big block, and it's basically a scaled up SBF. Once again it is true to correct engineering principles.
Originally Posted by Louisville Joe
The original Windor's were designed for and Falcon, Fairlane, and Comet, and they were a bit lacking for the larger cars.
221
The first engine of this family, introduced for the 1962 model year as an option on the Ford Fairlane and Mercury Meteor, had a displacement of 221 cu. in (3.6 L), from a 3.5 in (89 mm) bore and 2.87 in (72.9 mm) stroke, with wedge combustion chambers for excellent breathing. An advanced, compact, thinwall-casting design, it was 24 in wide, 29 in long, and 27.5 in tall (610 mm × 737 mm × 699 mm). It weighed only 470 lb (210 kg) dry despite its cast iron construction, making it one of the lightest and most compact V8 engines of its day.
In stock form it used a two-barrel carburetor and a compression ratio of 8.7:1, allowing the use of regular (rather than premium) gasoline. Valve diameters were 1.59 in (40.4 mm) (intake) and 1.388 in (35.3 mm) (exhaust). Rated power and torque (SAE gross) were 145 bhp (108 kW) @ 4400 rpm and 216 lbf·ft (230 N·m) @ 2200 rpm.
The 221 was dropped after the 1963 model year. There was also a short-lived stretched 240 version.
260
The second version of the Windsor, introduced during the middle of the 1962 model year, had a wider bore of 3.80 in (96.5 mm), increasing displacement to 260 cu. in. (4.3L). Compression ratio was raised fractionally to 8.8:1. The engine was slightly heavier than the 221, at 482 lb (219 kg). Rated power (still SAE gross) rose to 164 hp (122 kW) @ 4400 rpm, with a peak torque of 258 lbf·ft (350 N·m) @ 2200 rpm.
In 1962 and 1963 valve diameters remained the same as the 221, but starting in 1964 they were enlarged to 1.67 in. (42.4 mm) (intake) and 1.45 in (36.8 mm) (exhaust). Rated power was not changed.
In 1963 the 260 became the base engine on full-size Ford sedans. Later in the model year its availability was expanded to the Ford Falcon and Mercury Comet. The early "1964½" Ford Mustang also offered the 260, although it was dropped by mid-year, as did the 1964-1966 Sunbeam Tiger.
The special rally version of the Falcon and Comet and early AC Cobra sports cars used a high-performance version of the 260 with higher compression, hotter camshaft timing, and a four-barrel carburetor. This engine was rated 260 hp (194 kW) @ 5800 rpm and 269 lbf·ft (365 N·m) @ 4800 rpm.
Ford dropped the 260 after the 1964 model year.
260
I have a 62 Fairlane 500 with the 221 V8 that has 48,000 miles on it. The horsepower rating must be the old rating system that was "slightly optimistic" as the power is minimal with the 2 speed automatic transmission. They were good engines but the oil rings were so good that they scraped the oil off the cylinder walls so well it wore out the compression rings. As a result, they wouldnt use oil but they "puffed" out of the breather and would finally throw oil out of the filler. Remember, the 62 49 state cars did not have a PCV, only a breather tube on the rear (V8) or side (I-6) of the engines.
Redneckfordf2502002
09-28-2012 02:31 PM
66beater
03-08-2006 02:21 PM
No_BS
03-09-2005 11:50 AM
