whats needed
Old Mar 7, 2005 | 08:02 PM
stang30's Avatar
stang30
whats needed
i know this is a worn out topic but i havent heard for sure whats needed to swap a 300 to a 460 with a manual transmission. Or is it possible to stick a transfer case on the rear of a 2 wheel drive c6 and is it easier on the swap
Old Mar 9, 2005 | 07:07 AM
RTM's Avatar
RTM
What year truck? You need different frame pearches and motor mounts, different bell housing, flywheel set up for a manual trans. As for the C6 you need a 4X4 C6 trans to bolt a t-xcase to it. You can not just bolt a t-case on a 4X2 trans. The out put shaft is different and I believe there are two different adapters for two different t-cases, 203 and a 205. The manual trans can be had in two models as well and they both have there own adapters.
Old Mar 9, 2005 | 07:11 AM
stang30's Avatar
stang30
whats needed
Sorry its a 79 f150 4x4 with the np435 4 speed transmission
Old Mar 9, 2005 | 07:13 AM
banjopicker66's Avatar
banjopicker66
Your best bet is to do what I did, to buy an entire truck with the features you want.
You get all the correct parts, gizmos, doodads and thngamabobbies that hold your project up and drive you crazy trying to find.
I paid $300 for a rusted out dented up '77 F-250, with a 460/C-6, and I will transplant it into my '66 F-100 with a 352 and C-6.
The 460 needs rebuilding, but I'll sell the power steering and other parts off of it and will make most of my $300 back.
Jcabodi
Mar 10, 2017 12:53 AM
Mtrprts
Aug 20, 2016 11:27 PM
emeraldcoupe
Jun 16, 2016 07:35 PM
ss27gogeta
18
Jun 25, 2014 12:44 PM
19felix69
Aerostar
Dec 30, 2004 07:16 PM
