thinking about swapping in a np435
Old Jun 24, 2014 | 08:49 AM
ss27gogeta's Avatar
ss27gogeta
so my truck is an auto and a nice np435 with 205 transfer case comes up on craigslist yesterday. im wanting to swap over i know ill need pedals and a clutch but what else will i need to make this swap happen.
Old Jun 24, 2014 | 09:34 AM
redroad's Avatar
redroad
You currently have an auto with a married 205 transfer case ? and what you are looking at is a NP435 married to a 205 transfer case ?
Old Jun 24, 2014 | 10:05 AM
ss27gogeta's Avatar
ss27gogeta
yes they are both married
Old Jun 24, 2014 | 10:24 AM
ss27gogeta's Avatar
ss27gogeta
i looked under the truck the auto has a 203 married and the manual has a 205 married
Old Jun 24, 2014 | 10:59 AM
Alexz265's Avatar
Alexz265
You will need to give more info. What engine, what current trans? What year?
Old Jun 24, 2014 | 11:04 AM
ss27gogeta's Avatar
ss27gogeta
truck is a 78 4x4 it has a 460 out of a Lincoln mark 4 current tranny is an auto c6
Old Jun 24, 2014 | 11:05 AM
redroad's Avatar
redroad
The rear drive shaft will be different for starters .. It should be longer than what you have currently .. The transfer case mount is different on the 205 vs the 203 .. I'm not sure about the crossmember ..
Old Jun 24, 2014 | 11:10 AM
twinzilla's Avatar
twinzilla
Off the top of my head you'll also need:
Standard trans steering column (if you care)
Bell housing
Flywheel
Clutch assembly
Z-bar & linkage
Shifter
Floor plate (or you can cut the hole)
Driveshafts
I can probably help you out with most of that stuff if you decide to do it.
Old Jun 24, 2014 | 12:00 PM
ss27gogeta's Avatar
ss27gogeta
can i use my 203 from my auto or will it not bolt up to manual
Old Jun 24, 2014 | 12:36 PM
redroad's Avatar
redroad
yes you can use the 203 you'll need the housing that mates the two for a manual trans ..
Old Jun 24, 2014 | 01:23 PM
Alexz265's Avatar
Alexz265
There's 2 always to do this. Piece together all of it or order the kit from L&L products and piece together some of it. You need to know if your 460 is internal or external balance. Sounds internal and if so you could use a 390 flywheel and 302 pilot bearing. I'm doing a similar swap with a T-18 on a 79 2wd. That. Switch in balance was a running change for 78 so you have to check serial number. However a 390 flywheel wont fit in the bell with the clutch unless you make 1/2" spacer. Or order the kit like me from L&L. This is not a 1 weekend project. You also need to find the right pedal assembly (power brake / speed control) etc. Ford made 22 brake pedals and 7 clutch pedals for 73-79.
Old Jun 24, 2014 | 04:58 PM
ss27gogeta's Avatar
ss27gogeta
^ok so the tranny is out of a 78 and the pedal assembly I am getting off twinzilla is also from a 78 so I should be good there right
Old Jun 24, 2014 | 05:19 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
^ok so the tranny is out of a 78 and the pedal assembly I am getting off twinzilla is also from a 78 so I should be good there right.
Uh huh...
1973/79 F100/350:
There were TWENTY TWO different brake pedals, NINETEEN different master cylinders, SEVENTEEN different power brake boosters, SEVEN different clutch pedals, I kid you not.
Whatever booster you use must match the pedals.
Originally Posted by Alexz265
Switch in balance was a running change for 78 so you have to check the serial number.
Which serial number might this be? None.
The running change for 460's internal vs external balance occurred mid-model year 1979 .. not in 1978.
This only affects F150/350's and Econolines, since 1978 was the last year that 460's were available in cars, 1976 in F100's.
Running change means there were no before or from certain serial numbers or production dates.
460 ~ 1979 internal balance block casting number: D1VE-6015-AB2 / 1979 external balance block casting number: D9TE-6015-AB
Old Jun 25, 2014 | 09:03 AM
ss27gogeta's Avatar
ss27gogeta
So i did a little more research on the 203 and 205 because the info on the website i got it off of started to look like it might be wrong. from other pics from other sites so i crawled under the truck again and found the tag. it says it's a 205 so will i have to change my drive shafts since they will be the same transfer case.
Old Jun 25, 2014 | 09:25 AM
twinzilla's Avatar
twinzilla
You'll still have to change them because the auto trans is longer than the 4-speed.
