Windsor VS Cleveland???
Old Feb 28, 2005 | 01:47 PM
finnly56ford's Avatar
finnly56ford
i already have an AOD sitting in my garage just waiting to mate with something. so far I'd say I'm leaning towards the cleveland. I dont think i'd really be looking for aftermarket heads, but I am eventually in a year or two getting power steering and A.C., are the brackets somewhat easy to find or would i have to get some made up?? and i take it that the 2 barrel heads would be better then the 4 barrel for what i'm lookin for????
Old Feb 28, 2005 | 01:55 PM
fatfenders56's Avatar
fatfenders56
finnly/I have not had any particular difficulty finding brackets for clevelands because of the millions of 400s that were put in station wagons etc. I did make brackets to mount the a/c compressor down low on the passenger side just to get it out of sight but that was just that, to get it out of sight. I think vintage air makes other types of a/c brackets and march performance MAY have power steering etc. hope this helps
Old Feb 28, 2005 | 03:59 PM
huronfarmer's Avatar
huronfarmer
the way you boys are talkin, i need to get the 351 C out of the storage trailer and overhaul it......there again, then i gotta buy a new toy to put it in...:P
Old Feb 28, 2005 | 04:03 PM
fatfenders56
way to go huronfarmer, see how that works?
Old Feb 28, 2005 | 04:06 PM
Randy Jack's Avatar
Randy Jack
FF56 -
I didn't even consider the 400's for parts, but you're right. The blocks are the same. What year models would I find A/C and power steering stuff on?
Thanks
Old Feb 28, 2005 | 04:13 PM
fatfenders56
RJ, I don't know the production years, but have you ever seen a big sta wgon without p/s and a/c?
Old Feb 28, 2005 | 04:21 PM
Randy Jack's Avatar
Randy Jack
FF56 - Nope. Ok, I'll start scrounging...Thanks.
Old Feb 28, 2005 | 04:22 PM
286merc's Avatar
286merc
So how do you turn a 351M/400M into a 351C style performer?
Yards cant give away a M motor around here.
If I cant get the kind of truck power I need I may pull the stock 1985 351W 4V. But I need some serious improvement in a E350 dually 12' box truck and dont need as much as a 460 either. I cant believe this truck (1979) came with a 302!
Old Feb 28, 2005 | 09:34 PM
Randy Jack's Avatar
Randy Jack
286merc -
Your question got me wondering the same. I have a book called "Ford Perfomance" by Pat Ganahl (ISBN 1-884089-27-5). It discusses at length all the Ford engine families and what can be done with them.
The 400 was a big lumbering (160-170 hp) engine in the 335 (Cleveland) family that was put into many Rancheros, trucks and wagons. They came in 2-barrel models only and 8:1 compression. He says that they can be hotted up with many 351C parts and made to really scream. The exception is that the 400 is basically a 351C stroked an added .50 inch. This raises the block height, uses a different crank (with larger journals) and intake manifold.
He suggested that if TRW flat top 351C pistons, a 351C cam, an Edelbrock "Streetmaster" or Holley "Street Dominator" manifold with a 600-750 4-barrel carb were added, the compression would be around 10:1 and it would really move out with tons of torque on pump gas. The 400 rods need to be bushed for the smaller 351C piston wrist pins.
Sounds like a winner to me. I recommend the book. Good reading.
Old Mar 1, 2005 | 02:46 AM
bootie's Avatar
bootie
Originally Posted by airwick51
I have a 351 W in my 55 F-100 and have really looked hard into the possibility of putting on Cleveland 351C-2V heads. It just seems to be some minor machining of water passages on the heads and a wider intake manifold to make a Clevor.Or am I mistaken?? Will I have problems with my 1976 351W-2V block?
To be blunt YES!!!
you need to change the pistons as they require reliefs cut in them for the valves - other than that you have to acquire a street boss manifold or do a search for pricemotorsports - they sell adaptors to allow the fitment of different manifolds - i'm building up a 302 boss and using efi from a mustang, with all the other fruit keith black, trw, je and some others all make the pistons you want - do a search for clevor and you'll find alot more info
RJL1
Oct 5, 2016 01:09 PM
olblue77
May 31, 2016 04:43 AM
95ford4x4cowboy
May 14, 2005 09:30 AM
bootie
Aug 10, 2004 10:41 AM
mixed_up101
1978 - 1996 Big Bronco
Jun 27, 2004 08:01 AM
