351 windsor or cleveland
does anyone know if my 88' ford bronco xlt 4x4 has a 351 windsor or cleveland? if it is a winsor is the motor a good one or crappy, and would it be worth fixing the engine up, also how do i tell if it is a big block or small block, and also how do i tell if it is high ouput, and what is so special about high output, oh and the 351 is fuel injected
It's a Windsor. Cleveland engines haven't been built in the US in 30 years. Any Ford engine, if rebuilt properly, is a good engine. The 351W is in the same engine family as the 302, and is a small block. It's just a little taller, hence wider. I doubt very seriously if your engine is an HO. Mostly only cop cars and 93-95 Lightnings came with a 351 that could have been considered a fuel injected high output engine. I've never seen a fuel injected 351 that actually was called a 351 HO however. As far as I know, the last 351 HO was built in 84, and it had a carb. I'm sure if I'm wrong, somebody will step up. What's special about an HO engine is self explanatory. Higher Output.
