Something is Wrong!
Old Oct 30, 2001 | 08:25 PM
Hausladen's Avatar
Hausladen
Something is Wrong!
I have been getting really horibble gas mileage for an inline 6. I have replaced the gas line, gas tank, fuel filter, air filter, exhaust, gutted out catalic converter, replaced fuel pump, new sark plugs, wires, distributor cap, and rotor. After all this i get a big 8.07 miles to the gallon, no lie.
Any suggestions?
Old Oct 30, 2001 | 10:27 PM
Franklin2's Avatar
Franklin2
Something is Wrong!
What size truck?
What size tires?
What gear ratio in the rear?
Old Oct 31, 2001 | 07:22 AM
Hausladen's Avatar
Hausladen
Something is Wrong!
It is a F150 4x4, 4 speed manual tranny, short box, 31 inch tires, not sure what rear end it has.
Old Oct 31, 2001 | 08:09 AM
RGAZ's Avatar
RGAZ
Something is Wrong!
What year?
If its injected, check your fuel pressure and O2 sensor.
If its carb, adjust the jetting or rebuild the carb.
Randy
Old Oct 31, 2001 | 09:17 AM
Franklin2's Avatar
Franklin2
Something is Wrong!
One quick thing you can do that will make a big difference is tire pressure. If you have LT's look on the sidewall and see if it says "max cold press 50 psi". I usually run mine at 45 psi.
Old Oct 31, 2001 | 02:50 PM
Greywolf's Avatar
Greywolf
Something is Wrong!
Look around for vacuum leaks too...
The easiest way is to squirt small (repeat SMALL) amounts of starting fluid around lines and manifold areas that are suspect.
Take care to avoid sparks in the area, you don't want to start an engine fire!
Also, pull the line (it's a large diameter one) that feeds your power brake booster, and cover the port with your finger.
If any of these strike gold, you'll know because the engine RPM will change
Old Oct 31, 2001 | 02:52 PM
Greywolf's Avatar
Greywolf
Something is Wrong!
[font size="1" color="#FF0000"]LAST EDITED ON 31-Oct-01 AT 03:53 PM (EST)[/font][p]Almost forgot -
[font color="red" size="4"]
Distributor Timing
[/font]
if your timing is too retarded (past where it should be) you'll see mega-milage loss also
Old Nov 4, 2001 | 08:22 PM
rocky2's Avatar
rocky2
Something is Wrong!
You may also want to check if you have some stuck pistons in your calipers not releasing fully.
Old Nov 4, 2001 | 08:57 PM
ford86's Avatar
ford86
Something is Wrong!
mphurlbert
Feb 26, 2014 04:56 PM
jmm137
2004 - 2008 F150
Apr 11, 2011 02:56 PM
brcman
2009 - 2014 F150
Jan 8, 2011 05:22 PM
Cardinal Puller
Modular V10 (6.8l)
26
Jun 13, 2007 05:41 PM
Dan Robertson
1983 - 2012 Ranger & B-Series
Jan 3, 2007 09:05 PM
