Fuel Filter Change Issues
Old Apr 9, 2011 | 04:59 PM
jmm137's Avatar
jmm137
Im in the process of changing the fuel filter on my 2007 f150. I have removed the old filter and installed the new one, but I cannot get the fuel line from the gas tank connected to the filter. Am I missing a trick here? I tried pulling out the small blue flip on the fuel line and connecting to the filter but I still get a leak.
Old Apr 9, 2011 | 07:29 PM
Coskid's Avatar
Coskid
There is a tool that you need to complete the job from what I have read on here. I am not sure what the tool is called but I have heard it can't be done without it. Try running a search for fuel filter tool.
Old Apr 9, 2011 | 10:05 PM
Cofcmsc's Avatar
Cofcmsc
jmm I found this video helpful came from a link on the FTE site. Funky Fuel Line Disconnect - United States, AutoPro Workshop Video - Where Professionals Gather for Better Business
Best of luck
Shawn
Old Apr 10, 2011 | 01:44 PM
jmm137's Avatar
jmm137
well I had the tool but the auto parts store gave me the wrong size filter. Switched them out and went back together perfectly, thanks for the input!
Old Apr 10, 2011 | 08:21 PM
Coskid's Avatar
Coskid
Well glad you got it straightened out. Yeah the auto stores are good but not always perfect.
Old Apr 10, 2011 | 09:10 PM
jmm137's Avatar
jmm137
I also should have thought to compare the new one to the old one but didn't even think too. Still better going through that then paying the dealer to do it.
Old Apr 10, 2011 | 09:44 PM
alfack's Avatar
alfack
Yeah, there are two sizes for these trucks. The only difference being the size of the tubing, as far as I can tell. The flex fuel 5.4s take the filter with the larger diameter.
Old Apr 10, 2011 | 10:38 PM
jmm137's Avatar
jmm137
mine is a 2007 5.4, not flex fuel and it took the bigger diameter. Not real sure what would justify the difference?
Old Apr 11, 2011 | 05:18 AM
60DRB's Avatar
60DRB
Only Ford knows. It doesn't matter what engine you have. The filter size change was a running production thing (older trucks have the larger 3/8" size fitting). Some parts stores know this and some don't. Took me two trips to find that out too!
Old Apr 11, 2011 | 06:16 AM
sammer4u's Avatar
sammer4u
Same thign here. Went to local store, read the book only listed one part number, got it, installed it, started up and leaked like a son of a gun... Returned it and got correct one... good thing it was summer and no rain as I needed to use the bike to get the correct one!
Old Apr 11, 2011 | 11:03 AM
Oxxon's Avatar
Oxxon
Any chance of a pic of the tool and where one can be bought?
Old Apr 11, 2011 | 11:11 AM
alfack's Avatar
alfack
You only need one of these; the one that fits the size of your filter. I think this style is much easier to use than those $3 crappy metal ones, though.
Amazon.com: Lisle 39400 Angled Disconnect Tool Set: Automotive
Old Apr 11, 2011 | 12:17 PM
Rudeman's Avatar
Rudeman
When you guys shop for the fuel filter do you specufy the production year and drive configuration (2WD/4WD) of your truck? i know it sometimes makes a difference for other items like oil filters and the like. I guess you need to make sure the counter person actually specifies that info when searching for the part.
Old Apr 11, 2011 | 02:07 PM
evilwayz7's Avatar
evilwayz7
Another good idea and simple fix is to just take in your old filter and match it up to the new one. Side by side comparison of parts saves time, headaches and repeat trips to the store.
Old Apr 11, 2011 | 02:56 PM
alfack's Avatar
alfack
Yeah, or take a dial caliper and measure the outside diameter of the tube.
Or get one of each size and return the unused one. That's what I did, twice. I forgot that I had written the correct part number down in my service manual, after the first time.
Astoner165
2004 - 2008 F150
Dec 22, 2013 09:36 PM
Joes1Ton
Jan 9, 2013 01:21 PM
robertother
22
Jan 2, 2013 06:15 PM
fordtruck88
Jul 4, 2007 10:24 PM
Rob.D
13
May 2, 2004 07:37 PM
