help bed install
Old Jan 27, 2002 | 08:47 AM
deshet1980's Avatar
deshet1980
help bed install
Does any one know the proper bolts to use for the installtion of a bed on a f250 1982 model and also where I can get the rubber pieces. I mainly need the bolts sizes and I think that I will need eight of them.
Also how much is a f250 4x4 dually truck worth with a 95 mustang 302 with 40K on it.
thanks,
deshet
Old Jan 27, 2002 | 12:06 PM
FTE Ken's Avatar
FTE Ken
help bed install
Moved to the correct forum. In the future, please post in the appropriate section.
Old Jan 27, 2002 | 03:28 PM
Franklin2's Avatar
Franklin2
help bed install
If you took the original bolts out, you know they are special. I don't know where you would bet them besides the ford dealer(maybe). When I put my bed back on, I went to lowe's and bought 1/2" carriage bolts with large washers. Then I ground two flats on the head so I could put a wrench on them. I wonder what those body lift kits use?
Old Jan 27, 2002 | 05:23 PM
onestep's Avatar
onestep
help bed install
I would check out LMC, they seem to have a bunch of everything. Bed bolts and rubber bumpers included.
Old Jan 28, 2002 | 07:51 PM
Greywolf's Avatar
Greywolf
help bed install
*Sighs*
Educate me, Ken. Where did it go?
This is a 1982 problem, the man needs 6 bolts for the cab, and I believe 4 for the bed.
And rubber bushings are not as good as polyurethane. Those are for the cab only.
Any proper length hex head bolts with a 1/2 to 5/8ths shaft thickness should do the job. I would go heavier, rather than light.
I'd also go with grade 8 bolts, and locking nuts.
This is not a lift, and not necessarily body work. I haven't seen a frame specific forum, so I'm at kind of a loss here....
I hate to disagree, but I don't know what else to say.
I can't find where it was moved...
Old Jan 28, 2002 | 08:01 PM
Franklin2's Avatar
Franklin2
help bed install
Greywolf dude: He moved it here from somewhere else. And for your info. The bolts in my 80 which I assume are the same as his 82, are a special carriage bolt. The head with the square shank that fits in the bed is very large (larger than 1/2"). The threaded end of the bolt is close to 1/2". It tapers down from the large size to the smaller 1/2 end. That's why I had to use large washers on a 1/2" carriage bolt. The hole on the bed is very large. And I figured loading and inloading would be easier with the smooth top of a carriage bolt.
Old Jan 28, 2002 | 08:30 PM
Greywolf's Avatar
Greywolf
help bed install
Thank god! That makes sense....
(that it came here from somewhere else)
The lift kit I'm installing on my 82 has bolts that have a half inch shank. I think the heads are either 7/8ths or 11/16ths.
The Polyurethane replacements for the frame doughnuts are ideal because that are stiffer, and last a lot longer than plain rubber.
There will be a problem removing the old rubber mounts under the cab if they are rusted together. Just bend the wide bottom part with vice grips so that they look like taco shells, then cut out the rubber on the bottom and they should come out easily (lot's of room around them, theres a big hole in the perches).
The bed I don't think has rubber mounts, it's been a while sinse I could work on my truck.
But that changes this week!
I have a garage again....
(I just moved)
Old Jan 28, 2002 | 08:54 PM
Greywolf's Avatar
Greywolf
help bed install
deshet1980
1978 - 1996 Big Bronco
Jan 7, 2003 04:12 PM
deshet1980
Jun 6, 2002 05:08 AM
deshet1980
Feb 9, 2002 08:44 PM
deshet1980
Feb 8, 2002 08:49 PM
deshet1980
Feb 8, 2002 08:31 PM
