Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Garage Heaters
Old Feb 8, 2005 | 11:02 AM
koziol41's Avatar
koziol41
Garage Heaters
Looking for a good(portable) L.p heater for my workshop its about the size of a 2 car garage.Does anyone have a brand they prefer?What is better the Convection heat or the Radiant heat type?Will be used mostly for minor repairs oil changes etc.how many btu's do you recomennd.Thanks for your help.
Old Feb 8, 2005 | 10:52 PM
F150Conno's Avatar
F150Conno
I have a LP radiant heater in my garage. I think it has about 40,000 btu's. I got it at Home Depot for about 75 bucks. It cranks heat but makes me nervous, it's basically a gas grill turned sideways. I had an incident where it didn't light right away and I got the FOOOMPH and slightly singed my eybrows and eyelashes.
I don't think I would use it around flamable gasses.
Good luck
Old Feb 9, 2005 | 12:10 AM
laynrubber's Avatar
laynrubber
My opinion is that radiant is more efficient. Convection doesn't get the circulation around the room unless you have a fan blowing the air.
Old Feb 9, 2005 | 12:31 AM
Torque1st's Avatar
Torque1st
Posting Legend
The amount of heat you need will depend upon your location, insulation, type of construction etc, and how warm is comfortable to you. Check out some of the other threads here for additional information.
Old Feb 9, 2005 | 08:27 AM
kc2006's Avatar
kc2006
i'd say get the torpedo style ones. they're cheap and heat better because they blow the heat out where as radiant just sits there.
I bought a 55,000 btu kero heater for my 2.5 car garage and it takes about 10 mins to take the chill out and then put it at half temp and it's good to go.
Old Feb 9, 2005 | 08:40 AM
Momudder720's Avatar
Momudder720
Yup, agreed. I have a diesel-fired torpedo (120k btu's) for the shop (60x40x14) and it'll take the shop from 30 to 50 in an hour and a half, electronic thermostat and everything. Run's GREAT off the non-tax red fuel...
Old Feb 9, 2005 | 10:20 AM
gatesj's Avatar
gatesj
There were a couple of long threads in here on that not very long ago. Be careful with the torpedo heaters, they make at least some CO and you can get sick if you're not careful.
Old Feb 9, 2005 | 11:50 AM
BOORUMME's Avatar
BOORUMME
Thumbs up Garage Heaters
I just put a 45,000 btu Mr. Heater gas heater in my 2 car garage. It has a blower, and is vented to the outside with a horizontal vent pipe. I have it hanging from the ceiling, and this thing rocks. It is very quite, and lastnight while it was about 30 degrees outside, it took the temperature up to 70 degrees in about 45 minutes, and the thermostat shut it down, and kept it there easily. This is in a detached garage with no insulation yet.
Old Feb 9, 2005 | 01:41 PM
Momudder720
Hey Boo
Do they make those in the diesel/kerosene powered flavor, or just NG/LP?
Old Feb 10, 2005 | 06:53 AM
BOORUMME's Avatar
BOORUMME
Garage Heaters
Momu,
I didn't look to see if they are available in anything other than gas, but I'll check it out, and let you know.
Old Feb 10, 2005 | 07:09 AM
Crash687's Avatar
Crash687
Originally Posted by Momudder720
Hey Boo
those little Mr Heater(and simalar) unit heaters only come in NG/LP. You would have to buy a regular oil burner for #2.
judogold
Sep 10, 2016 12:23 PM
Blackdogf250
6.7L Power Stroke Diesel
Nov 4, 2015 09:17 PM
gfw1985
Garage & Workshop
Sep 28, 2015 05:23 AM
blueeyedfordguy
Garage & Workshop
27
Feb 17, 2014 11:23 PM
projectSHO89
General Automotive Discussion
Aug 19, 2008 08:59 AM
