Sponsored by: Real Truck
Heat not working
Old Sep 9, 2016 | 12:13 AM
judogold's Avatar
judogold
Heat not working
My heater stopped working. Any suggestions?
Old Sep 9, 2016 | 12:14 AM
judogold's Avatar
judogold
2007 f250 6.0
Old Sep 9, 2016 | 07:48 AM
RightWingNutJob's Avatar
RightWingNutJob
Besides "no-heat" what are the symptoms?
Does the fan work?
Does the diverter door switch from Defroster, to Vent, to Heat?
Or is it the Blend Door where it gets stuck and only allows the cold air to come through the system?
Old Sep 9, 2016 | 07:50 AM
MisterCMK's Avatar
MisterCMK
Check your coolant level. Does the heat work when the rpms come up? How about with a load or trailer behind the truck?
Old Sep 9, 2016 | 08:28 AM
judogold's Avatar
judogold
Thank you guys for the help.
Coolant level perfect.
Fan works on all speeds.
Vacuum pump runs till tank full.
Air switches on command to defrost, face, and foot.
A/C blows icy.
I think I will pull the blend control actuator behind the glove box and see if the arm rotates as I change temp ****.
Will also make sure heater core is hot too.
Old Sep 9, 2016 | 10:26 AM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
Make sure this valve circled in red has a grey vacuum line plugged into the front of it (it's unplugged in this pic), and that the valve changes position when Max AC is selected. This will block water flow through the heater core for Max AC operation, if it's stuck it would cause no heat:
Old Sep 9, 2016 | 08:01 PM
judogold's Avatar
judogold
The vacuum line to the valve circled in red is hooked up. The plunger retracts when the system is turned on, either toward A/C or defrost. It retracts when system is turned off.
The heater core is hot.
The white box with the 8 pin(5 wires) doesn't seem to be moving when I change the temp ****. I assume this is the blender door actuator? Heater core cover removed. How can I test the electrical connection?
Plunger to the left of that move up and down as system is turned on. And door inside that it controls moves with it.
Old Sep 9, 2016 | 08:43 PM
judogold's Avatar
judogold
OK. Update.
Removed white box on top of heater core(with the electrical connection). Took it apart. Cleaned grease from the prongs for the sensor. Plugged it in with the box in my hand and it now moves with the temp ****.
Problem. A few teeth are missing from one of the internal gears. Is there a rebuild kit for these? Ha Ha. I doubt it. Reinstalled and now door moves but it is chunky. (Because of the missing teeth).
I think I have this nailed.
Thank you guys for your help and fast responses!!!!!!
Power On
Old Sep 10, 2016 | 11:43 AM
5851a's Avatar
5851a
Thanks for update, always like to see the end to a problem.
Old Sep 10, 2016 | 12:23 PM
judogold's Avatar
judogold
Replaced the blender motor this morning. $105 (OUCH).
Back to melting my boots and smoking sausage on the dash.
Thanks for all the help!
Nico80
Nov 24, 2018 05:08 AM
bruceatlom
Nov 1, 2011 10:59 AM
knecoli22
Feb 21, 2010 09:23 AM
Hay Farmer
Jan 29, 2010 12:47 PM
Jed 16265
17
Feb 15, 2007 01:33 PM
