General Automotive Discussion
Large heater core recommendation?
Old Aug 17, 2008 | 09:01 PM
projectSHO89's Avatar
projectSHO89
I need a fairly large heater core to kludge together a cheap heat exchanger (for my garage) to add to my recently ordered outdoor wood burning furnace.
Anyone have a suggestion for a pretty good size one (large area, good flow rate, etc) that you've run across in any various vehicle?
Most heater core application charts go by vehicle make/model/etc instead of BTU transfer capability, so a suggestion on where to look first is requested.
Thanks,
Steve
Old Aug 18, 2008 | 05:37 PM
osbornk's Avatar
osbornk
I would use a radiator. They are easier to find and you would get much more heat out of them. Or you could use an old AC condenser.
Old Aug 18, 2008 | 06:57 PM
Lead Head's Avatar
Lead Head
I agree on the radiator. They flow more water, have a larger surface area, and much more flexible when it comes to the fans you can use. Plus, if you have to go to the junkyard, they are probably easier to remove from a vehicle.
Old Aug 19, 2008 | 06:26 AM
projectSHO89
A radiator will certainly work, just looking at the possibilities. Of course, a radiator's water connectors are going to take some "adapting"...
Steve
Old Aug 19, 2008 | 08:15 AM
osbornk's Avatar
osbornk
If you decide to use a radiator, you can get one with the electric fan already attached and you can simply use a converter and plug it in the wall. Since you don't need a radiator to fit a particular vehicle, you can bargain for one that there is little or no demand for and it should be really cheap.
Old Aug 19, 2008 | 08:59 AM
dragogt's Avatar
dragogt
Just a thought, but why not look for a rad from a BB truck?
nolan94f350
Sep 24, 2015 05:41 PM
rkmaxwel
1983 - 2012 Ranger & B-Series
17
Feb 15, 2015 02:44 PM
4x4 Bart
44
Mar 7, 2014 12:39 PM
changetheworld
Jan 11, 2014 03:48 PM
brimis
Sep 24, 2013 01:09 PM
