1978 - 1996 Big Bronco
Backup lights
Old Feb 3, 2005 | 09:46 AM
poffutt's Avatar
poffutt
Backup lights
89 bronco 351W c6
When I put her in reverse no backup lights come on. The fues is good. The bulbs are good. Where should I look next?
Old Feb 3, 2005 | 09:53 AM
Kemicalburns's Avatar
Kemicalburns
wires. is there power getting to the bulbs.
Old Feb 3, 2005 | 10:25 AM
poffutt's Avatar
poffutt
I would assume that no power is getting to the bulbs because the bulbs are not turning on. But the bulbs are new.
Old Feb 3, 2005 | 10:27 AM
Kemicalburns
correct if no power is getting there doesnt matter much that they are new. no power is no power. I would start at the rear and work forward. the wiring should be run inside the frame .
Old Feb 3, 2005 | 05:31 PM
poffutt's Avatar
poffutt
OK. the wires look in good order, but the shifter on the steering column has been tampered with. The wires are exposed. Is this where the switch is that triggers the rear lights? or is the switch on the trans.
Old Feb 3, 2005 | 08:18 PM
BroncoBoss351's Avatar
BroncoBoss351
I have a 93 bronco and sometimes my reverse lights wont go on and sometimes times they will.. its depends on how hard I put it into reverse.
Old Feb 3, 2005 | 08:23 PM
MatthewC's Avatar
MatthewC
There is a silver module on the drivers side of your transmission that turns the reverse lights on when you are in reverse. If your wiring is good, then this is your problem. These are cheap to buy, easy to install.
-Matt
Old Feb 3, 2005 | 08:42 PM
poffutt's Avatar
poffutt
Smile
Thanks Matt, I was lost as to where the switch was. I was about to tear my steering wheel off. I will check the switch at the trans.
Old Feb 3, 2005 | 11:23 PM
sacf250's Avatar
sacf250
is that the safty nutral swith??? I was told if that is disconected they wont come on either. Mine are out to so I will check that out too
Old Feb 4, 2005 | 01:30 AM
kameronth's Avatar
kameronth
I also thought that was the neutral saftey switch? Does it control reverse lights too?
Old Feb 4, 2005 | 08:02 AM
cjbronco's Avatar
cjbronco
definitly. I have an 82' and that was the prob. I replaced that and that was the problem. Now I got LED's and they are bright as hell.
ligito
Mar 3, 2015 03:34 PM
66F250CS
Apr 5, 2014 01:43 PM
jd-tom
Mar 27, 2011 07:45 AM
vmark
May 3, 2009 01:26 AM
rodsterman
Feb 21, 2004 12:27 AM
