Power Window Switch Replacement
Old Feb 1, 2005 | 01:49 PM
hoslaw's Avatar
hoslaw
Does anyone have a good cheat sheat for replacing the master power window switch and the right front power window switch?
(I saw the one on door lock accuators which was terrific - I'll be doing those this weekend!)
Old Feb 11, 2005 | 04:23 PM
Fleetsuper's Avatar
Fleetsuper
It is real easy, once you get the door panel off they just unscrew.
Door panel off, unhook wire connector, unscrew switch. If you read the door lock procedure, it tells you how to get the door panel off.
Big Mike
'00 Limited V-10 4x4
Old Feb 11, 2005 | 04:42 PM
Toyman's Avatar
Toyman
You should not have to remove the door panel to change just the switches. The switch panel itself has to come off to be able to remove the door panel. It is very easy to do.
Toyman
Old Feb 11, 2005 | 05:01 PM
cficare's Avatar
cficare
If you know how to replace the door lock actuators, then you'll have those switches off the door panel anyway. Jus' swap 'em out w/ new pieces.
juliomad
1997 - 2003 F150
May 22, 2017 07:28 AM
RSA7.3
1983 - 2012 Ranger & B-Series
Jan 8, 2017 12:16 PM
cypressdelight
Apr 24, 2016 01:55 PM
teamlx88
Feb 2, 2014 03:34 PM
Whitey Ford
3.0L V6
Sep 4, 2010 10:32 AM
