Sponsored by: Auxito
Power windows diagram
Old Apr 29, 2017 | 11:04 AM
juliomad's Avatar
juliomad
I am looking for a wiring diagram on the power windows for a 2002 F150 King Ranch. None of my windows will work from the master switch or from any of the window switches.
Old Apr 29, 2017 | 11:28 AM
projectSHO89's Avatar
projectSHO89
Did you check the fuse that runs the whole power window system?
Old Apr 29, 2017 | 11:47 AM
alloro's Avatar
alloro
Also check both the battery saver and accessory delay relays. The power for the windows runs through these as well.
When you turn the key off with the radio on, does it keep playing until a door is opened or no?
Old May 21, 2017 | 09:56 AM
juliomad's Avatar
juliomad
I have checked the main fuse, it is good. Also, the radio is pulled out because my son decided to try and install a new radio without really knowing what to do. This is why I was looking for a diagram. He did something and now none of the windows work from any of the switches.
Old May 21, 2017 | 10:02 AM
alloro's Avatar
alloro
Fuse #110?
Old May 21, 2017 | 12:21 PM
juliomad's Avatar
juliomad
No, #601. It's a supercrew.
Old May 21, 2017 | 02:12 PM
juliomad's Avatar
juliomad
I checked for power on the accessory delay relay. I have power on 86 and 30. Just for a test, I jumped 30 to 87 and the windows worked. I need to find out what triggers the ground to 85 on this relay. The drawing says a Generic Electronic Module is what triggers 85 on the Acc Delay Relay. What triggers that module? Or is that the module I need to replace? Please help!
Old May 21, 2017 | 05:30 PM
Sam I Am's Avatar
Sam I Am
Check the fuses for the GEM circuitS and battery saver relay circuitS in the passenger compartment fuse panel.
Old May 22, 2017 | 07:28 AM
juliomad's Avatar
juliomad
Thank you. I do believe it is something in the GEM. Fuse # F2.15 keeps popping. I have removed the GEM and will be looking for a replacement.
Super Duty Daddy
May 11, 2019 08:02 PM
Paradise Racing
Sep 1, 2015 02:59 PM
teamlx88
Jan 15, 2014 08:39 PM
ehudson
Dec 17, 2006 10:56 AM
theusc1
Nov 15, 2002 03:54 PM
