1999 power windows
Old Jan 7, 2017 | 07:49 PM
RSA7.3's Avatar
RSA7.3
1999 power windows
So my passenger window will go down but not up. I replaced power window relay under glove box. Voltage is 14 volts at motor but only one wire shows voltage going down and both wires show 14 v going up. Passenger window will not go up regardless of driver or passenger side switch. Any idea where to check ?
Thanks
Old Jan 8, 2017 | 12:13 AM
mfp4073's Avatar
mfp4073
have you checked the physical condition of the window regulator track/gears?
Old Jan 8, 2017 | 12:23 AM
RSA7.3's Avatar
RSA7.3
Yes the regulator is good. Changed a couple years back. Motor works in one direction even when it's removed from track.
Old Jan 8, 2017 | 08:57 AM
pawpaw's Avatar
pawpaw
Sounds like your loosing the ground connection in the up mode.
You can check the wiring pictorial for color codes here Search Wiring Diagrams
Old Jan 8, 2017 | 11:11 AM
RSA7.3's Avatar
RSA7.3
Thanks for the diagrams pawpaw. I really appreciate it.
Old Jan 8, 2017 | 12:16 PM
pawpaw's Avatar
pawpaw
Seeing as how you have B+ on both sides of the motor & ground is made through the drivers side master control switch assy, you might begin looking at the switch contacts, wiring & electrical connectors that provides the passenger side UP ground connection.
Seeing as how the drivers side switch will run the driver & passenger side windows Down, the open ground run would likely be between the two switches Up wiring/connector/switch contacts.
Broken wiring strands where the passenger door hinge flexes the wiring & switch contacts belong on the suspect list.
More thoughts for consideration, let us know what you find.
macdaddymatson
Mar 10, 2016 07:19 AM
vans
2009 - 2014 F150
Mar 20, 2015 09:23 AM
vans
2009 - 2014 F150
Feb 25, 2015 04:19 PM
nickh
General Automotive Discussion
Dec 15, 2007 07:11 PM
46fordtruck
Aug 30, 2004 05:54 PM
