1998 Ford Windstar Van passenger window not functioning. I checked but no power on switch. Does the driver and passenger windows share same circuit, or are they different?
I did in deed have power to the window motor, I found out. I had to remove window motor an inspect. To remove the window motor you must have a very sharp chizel to detach rivets which hold it. Take off power plug and remove. I had a debris caught in the spring. Removed debris and plugged motor in. Works great. Got bolts and nuts to replaced rivets, and mounted it back to the door. Works great, and even better it was FREE!
