Aerostar Ford Aerostar
Jacking up engine
Old Jan 29, 2005 | 03:32 PM
krankshaft's Avatar
krankshaft
Jacking up engine
I just got my oil pan partially down and loosened the motor mounts where do I jack up the engine from???
I will be using a block of wood on my jack to prevent damage to the metal.
Do I jack it up by the torque converter???
Old Jan 30, 2005 | 10:58 PM
asavage's Avatar
asavage
FTE Community Team
When I took my pan off two years ago Christmas ('89 shorty 3.0l AT), I had to jack up the engine about 1.5 inches to get the pan to clear the crossmember. I used a block of wood on the bottom of the harmonic balancer, and jacked against that. Worked perfectly. Watch the fan blades, you go any higher, you might break one. I carefully bent mine while jacking, and didn't loosen the fan shroud, but YMMV.
Regards,
Al S.
Old Jan 30, 2005 | 11:13 PM
krankshaft's Avatar
krankshaft
Thanks for the tip I will loosen the fan shroud too .
Old Feb 1, 2005 | 07:33 PM
aerovan's Avatar
aerovan
whoh.. by the harmonic balancer? wouldn't that warp the crankshaft? i don't know if it will... but that thought scares me!
Old Feb 2, 2005 | 01:26 PM
krankshaft's Avatar
krankshaft
It won't warp it if the engine is cool and you are only lifting the engine and not the whole vehicle then it would be trouble.
axelgawn
Jun 21, 2017 06:33 PM
t_dub
Oct 8, 2015 03:22 PM
TND
Jul 14, 2011 09:09 PM
Gage2502
Feb 22, 2011 07:17 AM
ghoyt87
2009 - 2014 F150
16
Dec 25, 2009 05:26 PM
