Dumb Jack Question?
Old Oct 7, 2015 | 07:35 PM
t_dub's Avatar
t_dub
Dumb Jack Question?
Need to finally tear my front wheels apart to re-do brakes and I want to jack the front of my F350 up with a bottle jack in the middle of the front axle so I can put jackstands under each of the normal jack points just inboard of the wheel? Is this safe? I know you can jack the rear from under the rear differential but definitely not the front from under the front differential.
Old Oct 7, 2015 | 10:43 PM
t_dub's Avatar
t_dub
OK, yes, poorly worded question but seriously, 75 views and no answers? can i use the center point of the front axle as a lift point to jack the front of the vehicle up????
Old Oct 7, 2015 | 11:27 PM
jswartz84's Avatar
jswartz84
Sure, if you can find the balance point. Why not jack one side up at a time and put the stands in?
Old Oct 8, 2015 | 02:07 AM
Yahiko's Avatar
Yahiko
That will be lifting 4,000 Lb give or take a few.
Safer to do one side at a time. Place the jack-stand inboard far enough so you can clean the tires.
I have found that lifting at the Radius Arm Axle Bushing for even lifting and being able to place a
jack-stand in the best location. The driver side is a PITA to lift at the axle tube and still get a jack-stand
under if your not lifting from the Radius Arm Axle Bushing.
Then if your lifting on an asphalt surface be sure to place something under the jack-stand so it does not sink.
Sean
6.0L Tech Folder
Old Oct 8, 2015 | 08:06 AM
bobv60's Avatar
bobv60
I would not use a bottle jack to lift the whole axle, front or rear. Its not stable enough.
Old Oct 8, 2015 | 08:13 AM
bobv60's Avatar
bobv60
There are some decent quality floor jacks available under $100
3 ton Low Profile Steel Heavy Duty Floor Jack with Rapid Pump®
I am not a fan of Chinese tools, but it will be had to find one NOT made in china
Old Oct 8, 2015 | 02:46 PM
Yahiko's Avatar
Yahiko
Your better off going a 4 ton do to the quality of some of these. That
being said I got one made by then in the 4 ton and it will lift the full
front no problem. The one thing I did not get was that rapid jack option.
Just what ever you do be safe.
Sean
6.0L Tech Folder
Old Oct 8, 2015 | 03:22 PM
TooManyToys.'s Avatar
TooManyToys.
I was one of those early views, but I held back. There was not one power train engineer I ever worked with who ever thought it was acceptable to lift an axle by the differential. And if a tech every tried to do so in front of one they would get a lecture.
Steven Stocki
Nov 13, 2016 03:13 AM
Thor'sHammer
Jul 13, 2016 02:20 AM
Yahiko
All Things Towing
Jun 19, 2016 10:51 PM
Citypol86
Mar 13, 2008 08:38 PM
cigarxtc
Mar 6, 2006 02:12 PM
