Jacking up Safely
Old Jun 21, 2017 | 05:58 PM
axelgawn's Avatar
axelgawn
Jacking up Safely
Where do you guys put jacks and jack stands when jacking up your trucks? I know people say don't put it on the I beam suspension. I have to use a block of wood just to get my jack to come close to reaching the frame. I am on stock height with 31 inch tires.
Old Jun 21, 2017 | 06:17 PM
ubereal2's Avatar
ubereal2
If your stands aren't tall enough, the frame is fine to use.
Unk Bob
lasermike's Avatar
lasermike
One front wheel, somewhere under the spring and shock.
Both front wheels, either one at a time as above with a jack stand under the frame or centered under the engine cross member.
For the rear, centered on the pumpkin or at whichever end needs to be in the air.
Official documentation,
Old Jun 21, 2017 | 06:21 PM
lasermike's Avatar
lasermike
I hate the mobile forum/iOS interface.
Anyhow, the above is how I jack it up, I use stands under the frame or ramps under the wheels to keep it up.
Michael
Old Jun 21, 2017 | 06:33 PM
351Cleveland C4's Avatar
351Cleveland C4
On the front, go from under the large bolt head where the radius arm and Ibeam come together. Or from the center frame under the oil pan. It is possible to lift from closer to center on the ibeam, but difficult as it likes to pivot.
On the Rear, either under the diff, the shock mount, or between the ubolts out on the end.
annaleigh
24
Jun 11, 2016 01:34 AM
hypophthalmus
Aug 21, 2012 12:45 AM
going slow
19
Mar 24, 2009 08:46 PM
psycosmith
1947 and Older Ford Trucks
Sep 14, 2007 11:06 AM
cigarxtc
Garage & Workshop
Apr 13, 2003 04:44 PM
