Offroad & 4x4
Odometer reading
Old Jan 24, 2005 | 06:17 AM
JeremyH's Avatar
JeremyH
Originally Posted by rebel_ford4x4
what would the actual speed difference be going from 235's to 31's?
When wanting to convert from metric to standard size, you need to provide the entire size of the tire. i.e. 235 75 R16 All of those numbers are used in the calculation.
235= tread width (in millimeters)
75= % of the value of tread width that is the sidewall
16= rim size (in inches)
So this example would yield a tire size of the following:
235mm= 9.3"
9.3" x .75= 7.0"
7" + 16"= 23" tire
Old Jan 24, 2005 | 07:03 AM
bremen242's Avatar
bremen242
235mm= 9.3"
9.3" x .75= 7.0"
7" + 16"= 23" tire
23.5cm x 1/2.54
9.25 x .75 = 7"
7" x 2 + 16 = 30"
your normal 235/75R15 would be
7" x 2 + 15 = 29"
you have to multiply the sidewall by 2, since it is round.
Old Jan 24, 2005 | 07:48 AM
JeremyH's Avatar
JeremyH
Yep, you are correct on that one! I did leave that part out.
F150vettehauler
2004 - 2008 F150
May 5, 2014 01:58 PM
Highheat18
2009 - 2014 F150
Mar 13, 2009 02:33 PM
minnesota4x4
Feb 28, 2006 03:56 PM
bjoern
May 9, 2001 08:44 PM
reuel_2
1997 - 2003 F150
Jan 12, 2001 04:46 PM
