nitrous on cast pistons?
Old Jan 19, 2005 | 07:16 AM
smoke n tires's Avatar
smoke n tires
i have a 78 302 with a mild build but stock pistons and 8.5-1 compression. i was thinking about adding nitrous, maybe a 75 shot max, my motor is fresh and i have a 5 speed, will i melt the pistons?
Old Jan 19, 2005 | 11:47 AM
Twinscrew's Avatar
Twinscrew
With the proper tune, cast pistons will last as long as forged and can actually provide some factor of safety against detonation. The cast piston run cooler and tighter than forged. They absorb heat more easily and because of the tighter side clearance can transfer what heat is absorbed to the cylinder wall more easily than forged. They will not, however, tolerate even slight detonation for very long. To ensure safety do your homework. Learn about ignition timing in relationship to the nitrous/fuel mixture and the role that bottle pressure plays. Always jet on the rich side for the fuel, provide adequate fuel pressure and flow, and make a hobby out of reading sparkplugs and you should never have a problem. I know of a cast pistoned 302 that was sprayed with two stages of nitrous to the tune of about 250 HP worth for 2 seasons and several hundred 1/4 mile passes. I was absolutely shocked to find pistons that looked almost like new during teardown. Just be warned, nitrous is veeerrry addictive....
Old Jan 19, 2005 | 04:24 PM
Capone's Avatar
Capone
using stock cast pistons is not recommended being that detonation will destroy them quite quickly. Stock cast pistons also DONOT have the compression rings lowered in relation to the piston crown like specialty pistons do. Yes the cast pistons do tighten up better than do the forged....which is why you would built a tight toleranced engine with the forged to mitigate the difference on this factor. The forged pistons will put up with detonation alot better and THIS is what I call a Margin of safety.
Mixture as well as timing will determine how the engine runs when the NOS kicks in. Running on the rich side will keep the engine on the safe side. Just be sure to bury the gas pedal so the secondaries open up and dump plenty of fuel. Also have the secondaries jetted for that shot of NOS. I also believe that you can get a timing retard setup from MSD that has a ping sensor.
Make sure your ring material is also up to the task....Total seal makes good rings
Be sure to do your homework...
Old Jan 19, 2005 | 04:58 PM
mark a.'s Avatar
mark a.
S.A. has a good book called Nitrous-Oxide Injection. Everything you ever wanted to know about it is in there.
Old Jan 22, 2005 | 11:57 PM
rusty70f100's Avatar
rusty70f100
Make sure it's setup right, and it's getting the proper amount of fuel. If it goes lean you're done. Keep the timing set right. If you have ANY doubt about the mechanical condition of your motor avoid nitrous. If you have something not quite right in there, nitrous will make it go.
Cast pistons run significantly hotter in the center than forged. This is a well known fact. Cast and forged pistons will run the same clearances when they're warmed up. Forged pistons will run more clearace when cold though.
Old Jan 24, 2005 | 11:05 AM
garsten's Avatar
garsten
the united engine and machine (they make keith black and silv-o-lite pistons) web site has an interesting tech article on the addition of nitrous to engines. it is pretty good, you should read it as an additional reference. good luck, garsten, tucson, az
Old Jan 24, 2005 | 10:35 PM
hotrodford87's Avatar
hotrodford87
I've got a 351W in an '87 Ranger that has made maybe 5 passes out of the last 1,000+ on n2o. All on Keith Black Hypereutectic pistons..you know, the one's you can't use with nitrous. I spray 75hp off the line and a second stage, usually 125-150, comes in down-track via an NOS delay timer. There are several good rules of thumb...keep 'er rich, take out 2 degrees of timing for every 50 hp of juice, 1-2 #'s cooler on the plugs, etc. Nothing however beats the advice from the n2o system provider. I use a CompuCar kit and picked up 2 tenths in a quarter mile over my old NOS brand because "Fast Eddie", the salesman that travels to all the FFW and NMRA races knows his stuff! Give him a call and he can set you up right the first time. You get what you pay for! And for sure...run a fuel pressure cut-off switch that will shut the whole system down if the fuel pressure drops below about 5psi on a carbed motor.
Old Feb 27, 2005 | 08:54 PM
Sunnude's Avatar
Sunnude
NOS an cast pistons, thats death eating kracker!!!!!!!!!!!
Old Apr 13, 2005 | 07:13 AM
cleatus12r's Avatar
cleatus12r
Butt-Head
One of my best friends was running a 250 HP shot on KB hypereutectics in his 454. He had NO problems, even during extended periods of use (MUD BOGGING). He went through 10 lbs. in a day. Probably put 150 lbs. through it with this configuration. Proper tuning and keeping the air/fuel a tad rich will save an engine.
'couse now he's running an 8-71 and 100 HP nitrous.......decided that hypers probably wouldn't take that, so he went forged.
Personally, I ran a 150 HP kit on my bone stock 460 for about a year (went through six 10 lb. bottles) before I got bored with 'the button'. Never a problem on casts, just kept it a tad rich.
Cody
Old Apr 17, 2005 | 02:34 PM
53wa2fl's Avatar
53wa2fl
I ran a 125 non-adjustable shot from NOS on my 302 with cast pistons for about 2 years with no problems. Then I took out the 302, put in a 351W with Kieth Black hypereutectic pop-up pistons...I've run that one for about 3 years now, and no problems...
77460ford
May 12, 2017 08:08 PM
DeckedoutF150
Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection
18
Feb 14, 2008 12:52 PM
46069dord
15
Feb 13, 2008 10:49 AM
bigred84
Feb 6, 2008 09:06 PM
moore89
Sep 20, 2003 07:14 AM
