Rolls backward in gear?
Old Jan 9, 2005 | 06:31 PM
Komodo's Avatar
Komodo
Hello all! I am new to the forum and have a question. I bought a used 2000 ford ranger XLT 3.0 with 5 speed manual. I bought it in florida and just got it home to nebraska and wondering if i might have a problem with my transmision. I have a somewhat steep driveway and when I parked it in first it sloowly and a little jerkily starts rolling backward. I can just use the parking brake but it gets kind of cold here and prone to freezing up. Do I have a problem or just a steep driveway? Thanks!
Chuck
Old Jan 9, 2005 | 06:48 PM
Dealford's Avatar
Dealford
Welcome to FTE!
Do a compression test on the engine. If all the cylinders read good then you've got a steep driveway.
If you drive the truck in nose first, you'll be able to reverse out if the p/brake gets frozen. Once you're on flat ground, you can yank & tug on the cables to free them up.
AL.
Old Jan 9, 2005 | 09:15 PM
el conquistador's Avatar
el conquistador
put it in reverse when you park it in your driveway, reverse has the highest gear ratio.
Old Jan 9, 2005 | 09:18 PM
danger_ranger_dude's Avatar
danger_ranger_dude
Yeah i agree with dealford, you might also want to have your clutch pad looked at if its really worn then that might be slipping. Might also have something to do with the clutch not applying enough pressure on the clutch pad, so that could make it slip as well. As always try the cheapest things first. good luck.
Old Jan 9, 2005 | 09:24 PM
Komodo's Avatar
Komodo
Thanks for all the info guys! I really appreciate it! I will start checking that stuff tomorrow.
Chuck
Old Jan 10, 2005 | 12:42 AM
B C fx4 Level II's Avatar
B C fx4 Level II
Steep Driveway, I have seen brand new Trucks roll backwards in first gear on very steep hills.
Old Jan 10, 2005 | 06:12 PM
el conquistador
that is why putting the truck in reverse is better than first gear, because its the highest ratio.
Old Jan 10, 2005 | 07:57 PM
Komodo's Avatar
Komodo
Thanks for all the info guys... I am parking it in reverse with the parking break on. I have never owned a pickup before so I wasnt sure.
Chuck
Old Jan 11, 2005 | 09:11 AM
Level2's Avatar
Level2
I miss my old 97 7.3 PSD!! You couldnt get that thing to budge in gear on a hill with a trailer on it LOL!
sumbuddyloanmea.10
Nov 16, 2010 02:01 AM
baker_racing05
2004 - 2008 F150
13
Jul 25, 2006 08:42 AM
yellow98cobra
2004 - 2008 F150
15
Mar 31, 2006 07:57 AM
fuchs4
Dec 26, 2005 09:38 AM
mhyff250
May 11, 2000 09:26 AM
