Transmission problem or not?
Old Jul 23, 2006 | 05:01 PM
baker_racing05's Avatar
baker_racing05
I just bought a 2004 F-150 Supercrew and if im sitting on a steep incline like at a stop light or something and I let off the brake it will start rolling backwards. The pickup has 24,000 miles on it and still under the factory warranty. I also have a 87 F-150 and if im sitting on a steep incline it will not roll back when I let off the brake it will just sit there. Just wondering what some of you think I should do, take it into the dealer and have them look at it?? Thanks for the help
Old Jul 23, 2006 | 06:26 PM
awu_gigabyte's Avatar
awu_gigabyte
My 06 does the same thing. I'm assuming its normal
Old Jul 23, 2006 | 06:52 PM
projectSHO89's Avatar
projectSHO89
You're supposed to keep your foot on the brake when stopped.....
Steve
Old Jul 23, 2006 | 07:06 PM
WhëëlMå1's Avatar
WhëëlMå1
Welcome to FTE baker_racing. Unfortunately, I dont have a good answer for you. My 04 did that (do not own anymore). Have not noticed if my 06 does it....but I know a number of trucks on this forum have done it over the years.
Old Jul 23, 2006 | 07:12 PM
hadaford's Avatar
hadaford
Maybe your Idle is set too low and not giving enough revs to the torque convertor.
Old Jul 23, 2006 | 07:15 PM
tonyw4z1l's Avatar
tonyw4z1l
I do believe Ford designed the transmission this way. When you are driving at speed and you let off the accelerator the truck will "coast" rather than decelerate due to engine braking. A side effect of this is that the truck will roll backward when on an incline. My 2005 does it and I think it's normal.
Old Jul 23, 2006 | 07:18 PM
WhëëlMå1's Avatar
WhëëlMå1
^^^ Good point. Ford is trying every trick in the book to keep the EPA off their back when it comes to mileage for their fleet.
Old Jul 23, 2006 | 07:32 PM
baker_racing05
Ok, this makes me feel better now. I was getting kinda worried there for alittle bit, thanks for the help
Old Jul 24, 2006 | 07:26 AM
ford9c's Avatar
ford9c
My 04 does the same thing. If you are sitting at a light on a hill, you better be quick taking your foot off the brake and putting it on the gas. If not the truck will be rolling down the hill backwards at breakneck speeds.
Old Jul 24, 2006 | 10:44 AM
Abaddon's Avatar
Abaddon
Yep same here. My 04 will also roll backwards.
Old Jul 24, 2006 | 12:22 PM
jwh2car's Avatar
jwh2car
Same here. My son even commented that his Mom's Tundra will roll forward if you let off the brake. My truck will not and will roll backward on a hill. Mine is an '04 F150 Screw, 4x4 w/5.4L, and 3.73 ls.
Old Jul 24, 2006 | 02:21 PM
awu_gigabyte
if i'm on a hill, say backing up to a trailer, i gotta do the ol' one on the gas, one on the brake or i'll never get it backed up right.
Old Jul 24, 2006 | 09:29 PM
Phoenix250's Avatar
Phoenix250
Yep my 05 does the same thing. This is normal.
Old Jul 25, 2006 | 08:42 AM
KevinM's Avatar
KevinM
Nope mine holds up to a point, it depends on the grade, interstate off ramps it holds very well. These trucks do not coast, the reason they feel they are not engine braking on deceleration is because they are in overdrive 0.77:1. Unless they down shift you will feel as though they are coasting but in reality are braking but not as hard as you would expect. Try taking overdrive off and you feel more resistance while decelerating.
flixden
2009 - 2014 F150
Mar 20, 2012 09:57 AM
KJKozak2
Offroad & 4x4
May 25, 2007 11:36 AM
kevlm
2004 - 2008 F150
Nov 19, 2006 10:21 PM
yellow98cobra
2004 - 2008 F150
15
Mar 31, 2006 07:57 AM
Kendall
2004 - 2008 F150
21
Nov 22, 2004 10:18 AM
