harmonic balancer
Old Jan 6, 2005 | 08:02 AM
wdb1971's Avatar
wdb1971
harmonic balancer
I have a 94 f150. I swapped my 5.0 with a junkyard 5.0. I just got it running after replacing ,the cat ,injectors ,o2 sencer ,and a tuneup. the motor still shakes like it has a fouled plug or wire. when i swapped motors should i have left the harmonic balancer with the motor it came with?????
Old Jan 6, 2005 | 12:14 PM
Matts72's Avatar
Matts72
Yes.
If you still have the old one, check the engineering number, if they're the same, you need to look elsewhere. If they're different, you found the problem.
Old Jan 6, 2005 | 12:31 PM
Matts72's Avatar
Matts72
well thats interesting....
Old Jan 6, 2005 | 01:11 PM
yomow's Avatar
yomow
Use the 5.8 firing order, the 5.0 you got may have came from a mustang or some one put in a 5.8 camshaft . Most of the hormonic balancers are the same . thay changed by years .
Don
Old Jan 7, 2005 | 09:19 AM
wdb1971's Avatar
wdb1971
harmonic balancer
thanks for the info. i've been a ford owner about 6 yrs. i'm still learning about the ford 5.0
Old Jan 9, 2005 | 10:06 AM
wdb1971's Avatar
wdb1971
Question harmonic balancer
engineering number on the harmonic balancers are the same but i switch them anyway to be sure. i don't know the firing order for a 5.8 i.ll try it as soon as i can get it. because it still shakes and will not keep it's idle i've also set the base timming and plugged in the spout connecter and the timming don't stay at 10 deg btdc.... i also disconnected the neg termonal to clear the computer
Old Jan 10, 2005 | 08:08 PM
wozxxx86's Avatar
wozxxx86
1-3-7-2-6-5-4-8 is the 5.8 firing order or 95' and later 5.0's
Old Jan 11, 2005 | 03:24 PM
wdb1971's Avatar
wdb1971
harmonic balancer
wozxxx86
found that my 94 5.0 has the same firing order as the 5.8
the only thing i left to check is my fuel pressure and compression test my cylinders. i'm begining to think that i might have a bad fuel pump or head or gasket
warren
Old Jan 11, 2005 | 05:48 PM
wozxxx86's Avatar
wozxxx86
well u said it sounded like a cylinder was missing, mayb its a bad injector...assuming this is efi, the only other cause might be the flex plate if its an auto cause ive heard that there were different weights for the 5.0's of diff yrs. or bad compression, or check the disty cap mayb sumthins jacked in there, and that wouldnt be a very expensive fix
bigperm2
Sep 12, 2022 10:12 PM
36545f150
15
Feb 18, 2017 08:13 AM
JRS2
Apr 15, 2014 08:57 PM
jj22ee
Feb 25, 2011 07:37 PM
Determan
Jun 23, 2001 07:02 AM
