points conversion
Old Dec 27, 2004 | 05:34 PM
ford390gashog's Avatar
ford390gashog
Question points conversion
i want to convert the unreliable points in my truck to electronic pickup i am having a hard time making a decision.I am looking at either the pertronix or the crane cams XR-1 setup with built in rev limiter the pertronix is 85.00 the crane is 75.00.Ehich one is the better of the two it needs to be reliable.
Old Dec 27, 2004 | 07:12 PM
stephenw's Avatar
stephenw
I think I remember the distributor guru on the FordFE.com site, Faron Rhoads, say that he would never use the Crane setup!?! You might take a look on that forum and do a search.
FWIW, I have the Pertronix II system on my hi-boy, and it did fail once. The beauty of the Pertronix is that IF anything ever goes wrong, you just stick in the set of points and condensor that you kept in your glove compartment, re-time, by ear if necessary, and you are on the road again. That's what I did, and was back to civilization again in no time. The failure was when it was pretty new, and hasn't given me any more trouble in about 3 years now. The Pertronix II has better electronics, will not burn itself out if you accidentally leave the ignition key on when engine's not running, and supposedly stretches out the spark duration when you are running under 3K RPM.
Steve
Old Dec 27, 2004 | 08:16 PM
baitmaster's Avatar
baitmaster
My Pertronix has been in for over 8 yrs, only changed the cap and wires once. (I've saved a bundle on points in that time).
Old Dec 27, 2004 | 09:15 PM
ford390gashog
the "Ehich" was supposed to be "which" i hit the wrong key.
Old Dec 27, 2004 | 09:18 PM
Putt's Avatar
Putt
I have used and recommended the Pertronix. I am happy with the reliability, about 70-80,000 miles without a problem.
Old Jan 23, 2005 | 08:44 AM
maverick man's Avatar
maverick man
use a duraspark distributor and brain out of a 460. cheap conversion...
Old Jan 23, 2005 | 01:03 PM
bluesky636's Avatar
bluesky636
Pertronix. Best on the market.
Old Jan 23, 2005 | 07:24 PM
KCampbell's Avatar
KCampbell
Another happy Pertronix customer, here. Fit it and forget it.
Kevin
johninraleigh
Electrical Systems/Wiring
Oct 17, 2007 10:01 AM
360 Sport Custom
28
Nov 4, 2006 11:11 AM
Jag Red 54
15
Oct 26, 2006 09:45 AM
66MercMan
Jan 29, 2004 06:41 PM
73tank
Jun 3, 2003 09:26 PM
