Just bought 03 F250 with XLT package. Truck has electric door locks, but not keyless entry. Does anyone know if this option can be added? I am sure an extra relay and of course a key flob is required, but is the wiring already in place?
Hi,
I have the same truck without remote entry. I was thinking of the same thing. There is a Ford dealer on Ebay that sells a factory Ford keyless entry kit. It contains a glue on keypad for the driver's door, but I do not know if it contains any remotes. I E-mailed them numerous times with no response.
Take a look and see if you can make heads or tails of it. Try to contact them--Maybe you will have better luck than I did. The Ebay item# is <!--StartFragment --><TD nowrap="nowrap" align="right">7941411888</TD><TD align="right"></TD> . Do a search for that item. I tried to post the url, but it did not work properly.
Let's try this again--my previous post came out all screwed up.
Hi,
Take a look and see if you can make heads or tails of it. Try to contact them--Maybe you will have better luck than I did. The Ebay item# is <!--StartFragment --> <TD nowrap="nowrap" align="right">7941411888. Do a search for that item on Ebay.
I need to clarify my request for information on remote entry. I do not neccesarily want the keypad for "keyless entry". I just want to add the electronic stuff required to use a remote with my existing power door locks. Is this easier?
Yes, you can add it. From what I can tell, the wireing is not there. You need one of the Ford Powercode systems and a couple relays to install it. It doesn't look that hard, I have one sitting here I am going to install after Christmas. Been to busy to install it yet.
