Sponsored by: Real Truck
Adding Keyless Entry
Old Dec 22, 2004 | 07:44 PM
richartdana44's Avatar
richartdana44
Question Adding Keyless Entry
Just bought 03 F250 with XLT package. Truck has electric door locks, but not keyless entry. Does anyone know if this option can be added? I am sure an extra relay and of course a key flob is required, but is the wiring already in place?
Old Dec 22, 2004 | 07:53 PM
Rongold's Avatar
Rongold
Remote Entry
Hi,
I have the same truck without remote entry. I was thinking of the same thing. There is a Ford dealer on Ebay that sells a factory Ford keyless entry kit. It contains a glue on keypad for the driver's door, but I do not know if it contains any remotes. I E-mailed them numerous times with no response.
Take a look and see if you can make heads or tails of it. Try to contact them--Maybe you will have better luck than I did. The Ebay item# is <!--StartFragment --><TD nowrap="nowrap" align="right">7941411888</TD><TD align="right"></TD> . Do a search for that item. I tried to post the url, but it did not work properly.
RON
Old Dec 22, 2004 | 08:03 PM
Rongold's Avatar
Rongold
Let's try this again--my previous post came out all screwed up.
Hi,
Take a look and see if you can make heads or tails of it. Try to contact them--Maybe you will have better luck than I did. The Ebay item# is <!--StartFragment --> <TD nowrap="nowrap" align="right">7941411888. Do a search for that item on Ebay.
RON</TD><TD align="right"></TD><!--StartFragment -->
Old Dec 22, 2004 | 08:09 PM
richartdana44
I need to clarify my request for information on remote entry. I do not neccesarily want the keypad for "keyless entry". I just want to add the electronic stuff required to use a remote with my existing power door locks. Is this easier?
Old Dec 22, 2004 | 08:23 PM
Gt-358's Avatar
Gt-358
Yes, you can add it. From what I can tell, the wireing is not there. You need one of the Ford Powercode systems and a couple relays to install it. It doesn't look that hard, I have one sitting here I am going to install after Christmas. Been to busy to install it yet.
This site has the kits http://www.fordgenuineaccessory.com/Ford/Super_Duty.Remote_Start_Systems.4.htm
You can get just a Keyless entry kit, or a Keyless plus alarm, or the one I got does Keyless, Alarm, and remote start.
You can find them cheaper if you look around. Just do a search for the part # 2W7Z19G364AA
edit: http://www.ford-trucks.net/forums/sh...d.php?t=298178 <-- here is some more info on the kits
2Wise4aGM
Sep 19, 2010 04:12 PM
fishinford
2004 - 2008 F150
50
Feb 17, 2009 08:32 PM
chapinjohn
1997 - 2003 F150
20
Oct 17, 2007 10:01 AM
bkaeding
1997 - 2003 F150
Nov 2, 2003 02:54 PM
Aug 25, 2002 10:40 PM
