General Automotive Discussion
best preventative maintenance
Old Dec 1, 2004 | 10:22 AM
nastruk95's Avatar
nastruk95
Arrow best preventative maintenance
What are some of the best things to do to keep the automobile going besides changing fluids? Recently I took out the door sills, cleaned and waxed underneath, Took out the bed liner and waxed the paint and greased any shiny metal spots. I was thinking about waxing inside the fenderwells and truck bed. I de-rusted the spring shacles and painted them. Any other good ideas?
Old Dec 1, 2004 | 10:30 AM
kc0rey's Avatar
kc0rey
Clear the drainholes in the doors.
Old Dec 1, 2004 | 10:35 AM
85e150's Avatar
85e150
Dump the bed liner and go with a spray in job and rail protectors.
Old Dec 1, 2004 | 11:31 AM
nastruk95's Avatar
nastruk95
I heard that putting underbody coating does worse than better if you put it on yourself and is not from the factory.
Old Dec 1, 2004 | 12:51 PM
jim henderson's Avatar
jim henderson
Crawl around under the truck and try to shake or twist any components that look like they might come loose. Like, shocks, tie rods, rock shields, exhaust and shields, cable mounts, gas tank straps, running board mounts, stuff like that. If you find a loose part fix it. I find something loose or missing more often than I would like to think. Also cures many strange noises. Catches many parts just before they fall off and cost you some money.
A good wash and wax will help the paint. Some upholstry cleaning/treatment helps.
Check your motor and tranny mounts once in awhile.
Check and lubricate brake components. IE. lubricate the sliders or other sliding parts of the calipers etc, not the pads of course.
Good Luck,
Jim Henderson
Old Dec 2, 2004 | 07:11 PM
ampegor's Avatar
ampegor
If your truck is efi take apart all the wiring connectors and put a dab of dielectric grease in then before putting them back together (especiall fuel pump relay sockets)
Andy
Old Dec 2, 2004 | 07:32 PM
68 351 bronc's Avatar
68 351 bronc
Best prevenitive maintance is how you oporate the vehickle. Easy on the clutch, same with brakes. Don't rev the engine cold. If the transmission is a manual feel it into gears don't force it. If it is an auto pull it down a gear if it's shifting when it doesn't need to like in heavy traffic. Don't slam the doors. Find a safe place to park it even if you have to walk a little further.
Old Dec 2, 2004 | 07:34 PM
hdgapeach's Avatar
hdgapeach
Shoot me if I'm wrong, but most all undercoatings are applied by the dealerships prior to selling, not at the factory.
The forgotten list:
Lubricate hinges (door, tailgate, hood, vent window, etc....)
Tire inflation to specs.
"Proper" tune up (includes at least blowing out the air filter and setting timing)
Correct carb adjustment (rebuild it every few years whether you think it needs it or not and set the choke to specs.
Flush brake system with new fluid every few years
Coolant level and condition check
V belts
Windshield wipers
This stupid list won't ever end!
Old Dec 3, 2004 | 11:17 AM
nastruk95's Avatar
nastruk95
I've heard putting peppermint oil on all the studs or threads that are exposed will help in the long run in case you need to remove them, supposedly the peppermint oil is just as good as a corrosion/rust inhibitor.
Old Dec 3, 2004 | 01:08 PM
dhermesc's Avatar
dhermesc
Couple of maintenance items I'm vigilant about - track down vibrations as soon as you notice (broken belt in tire, out of balance, alignment, warped brakes...) with all the electrical parts & connections in a modern vehicle no point in trying to vibrate them apart. Running fuel injection cleaner on a regular basis (lot of stations are selling dirty gas) and keeping the fuel filter fresh.
One area I've been kind of bad about - belts and hoses (except timing belt). I've never broke a belt or hose on a vehicle in my life - and thats with some getting way over 150K and ten - twenty years of service. The only time they might get changed is when another part fails that requires they be removed (water pump, altinator etc).
Old Dec 3, 2004 | 01:16 PM
Aftrmidnite's Avatar
Aftrmidnite
There is a book that comes with every Ford, its Called "Scheduled Maintenance." Even has little check off bubbles. I also write any other service done in this manual.
2006powerstroke90
Oct 4, 2011 07:56 AM
Flaw
Appearance & Dress-Up
75
Jul 28, 2007 08:13 AM
my72ford
Bronco II
Apr 10, 2006 03:59 PM
TX4x4screw
13
Apr 6, 2005 04:12 PM
fetterjohn
Jun 28, 2002 11:40 AM
