wind noise
Old Apr 27, 2005 | 01:28 AM
  #61
ELO168's Avatar
ELO168
got the truck back from dealer today
after 4 long days
reseal the windshiled inside and out
noise still there
the service advisor thought i was pulling his leg
went for a ride with him, suprise he heard it too.
so the truck went back for the fourth time
he said the svc mgr well have a chat with the ford engineering
well hope they fix it this time or lemon law here it comes
thanks
Old May 3, 2005 | 07:56 PM
  #62
ELO168's Avatar
ELO168
guess not
the wind noise still there
p/u on saturday
still there, darn it how many times do i have to go back?
well i called the ford motor company today
made a huge complain and they will get back to me tomorrow
will keep you guys posted
Old May 3, 2005 | 09:52 PM
  #63
Ruckus's Avatar
Ruckus
Do Not hold your breath for that return phone call.I have only found deaf/non caring ears at FoMoCo.Good Luck!
Old May 6, 2005 | 02:59 PM
  #64
ELO168's Avatar
ELO168
fmc did call me back
they said go back to the dealer and a ford engineer will come
lets see waht happens
also they told me if they can not repair it
i can put a request to them what i want to do
well keep your guys posted
thanks
Old May 6, 2005 | 05:52 PM
  #65
keith Ruge's Avatar
keith Ruge
This is a long thread , DID any body ever get a wind noies in the drivers side door I think thats where Im getting mine I have a screw , The dealer has already replaced the plastic between the doors BUT it still does it but knot as much ??
Old May 10, 2005 | 08:43 PM
  #66
ELO168's Avatar
ELO168
this is getting ugly
drop of the truck on sunday to the dealer again
call them yesterday, nothing was done to the truck
so i called fmc, file anoterh complain against this dealership
called them back again today, the svc mgr did not want to call ford engineer down to check the problem, he said is a normal sound
thas is so funny, first of all i did not have it when i got the truck
second if is so normal, why did they try to fix it for so many times?
replaced the windshield and re-seal it 3 times?
well i told fmc they need to buy back my truck.
it will take 5-7 days for the board to have a result
if not lemon law here it comes.
thanks
Old May 10, 2005 | 08:44 PM
  #67
ELO168's Avatar
ELO168
btw
i am in so, cal
the dealership is wondries ford
the svc mgr is john milton
thanks
Old May 19, 2005 | 01:01 AM
  #68
ELO168's Avatar
ELO168
took the truck to another dealer
suprise they said is not normal sound
also whoever installed it seems they where doing it for the first time
however ford could not authorize them to work on it
have to take back the original dealer that install the windshield
love to see the svc mgr when i show him the repair order is not normal
also contacted my lemon law attorney
they said either ford buy back or fmc will pay me for all the trouble i went thru
and still keep the truck
hornestly i don't want to keep the truck
forgot to mention it leaks from the back window now
also in for second time for brake vibration
let's see what will happen
thanks
Old Mar 2, 2006 | 12:10 AM
  #69
ELO168's Avatar
ELO168
is coming from the windshield due to inproper sealant
i had mine back at the dealer 7 times
change the windshield twice
still no luck, and dealer to me is normal, (funny)
so i took it to the lemon law
is in the process now, almost been a year
you guys should save all the service order and file a lemon law against ford
thanks
Old Nov 24, 2007 | 09:42 AM
  #70
jlwpac's Avatar
jlwpac
Hi folks. I've had my '04 F-150 for obviously 4 years. The noise is the front cowling vibrating against the windshield. I've had mine replaced and it still does it. The only solution I've found is to run a bead of black silicone along the cowling and the windshield. This does work, but has to be redone every 6 mos. or so. At least until I find a better quality silicone. I learned this trick approx. 2 years ago right here on this site. Good luck!
Old Nov 24, 2007 | 05:41 PM
  #71
ledwards's Avatar
ledwards
Smile Wind Noise In Windshield Fixed For Good!
I have a 2005 F-150 which had a real bad wind noise in the windshield area. I duct-taped the entire top of the windshield and the noise went away.Eventually my dealer noticed the silver duct tape and offered to put in a new windshield. It was only marginally better so I duct-taped it again. The noise disappeared again. Finally I was lucky enough to get a rock in my windshield and had to replace it again. This time my glass installer put a rubber gasket in at the top just like they used to before Ford tried to save some money. There is no wind noise at all now. There was no extra charge for the the rubber gasket either as it is quite cheap.
Quiet In Canada
TheStig80
2015 - 2020 F150
44
Oct 9, 2016 03:01 PM
akappler
2009 - 2014 F150
29
Sep 4, 2014 03:52 AM
Flash635
13
Feb 15, 2013 10:17 PM
1967 Turbo 6.9
Jan 1, 2011 01:26 PM
Toreador
2004 - 2008 F150
23
May 5, 2004 12:57 AM
