electrical problem- please help
Old Nov 28, 2004 | 12:08 PM
liljase's Avatar
liljase
I have an 86 F150 (302,auto,4X4) and I have an electrical problem.I have no running lights or instrument lights.My headlights work and interior lights work.Blinkers and brake lights also work.The fuse for the parking lights has juice but they still dont work.The instrument light fuse however has no juice to it at all.I am just wondering if they are connected somehow because both stopped working at the same time.I turned on the headlight switch and heard a pop now I have these problems.Any ideas or help would be greatly appreciated.Thanks in advance.
Old Nov 28, 2004 | 12:36 PM
FordF150Fixer's Avatar
FordF150Fixer
I would suspect the headlight switch itself. They are inexpensive and easy to replace. Please let us know what to problem turns out to be.
Old Nov 28, 2004 | 05:13 PM
5_labsownus's Avatar
5_labsownus
The headlight switch is noted for going out in just about the manner. I would suggest replacing the switch plug. The get hot and melt as does the wires close to the plug!
Old Nov 28, 2004 | 06:18 PM
liljase's Avatar
liljase
I will get a headlight switch in the morning and replace it and than post an update,thanks for the help.
Old Dec 3, 2004 | 04:50 PM
liljase's Avatar
liljase
I just wanted to thank you guys for the help you saved me alot of testing and digging.Turned out to be the headlight switch.Only an $11 fix.Thanks again.
Old Dec 4, 2004 | 01:32 PM
5_labsownus
No problem! When you replaced the switch did you look at the plug to see that it's in good condition?
Old Dec 4, 2004 | 06:58 PM
Holmesuser01's Avatar
Holmesuser01
Thumbs up dual troubles!
I've replaced the headlight switches on both of my F-150's. The '84 burned up the plug. The '83 just had an intermittent dimmer. I cleaned all the plug blades while I had the switch out. Lots of dirt and corrosion builds up over the course of 20 years or so...
Old Dec 5, 2004 | 03:33 PM
liljase's Avatar
liljase
The plug seemed to be ok.I did clean off a little dirt and currosion.Thanks again for the help.
shakedownshorty
Nov 20, 2014 12:38 AM
37 Ford guy
Jan 15, 2013 12:03 PM
stephsG37
Electrical Systems/Wiring
Jun 8, 2012 11:44 AM
jaylie
20
Oct 7, 2011 07:22 PM
DieselBeast01
13
Jun 26, 2008 12:40 PM
