Neutral Safety Switch Questions
Old Nov 13, 2004 | 06:35 PM
MnBoomer's Avatar
MnBoomer
Have 1977 F150, 2x4, auto, 460. Replaced neutral safety switch today as truck started in every gear and reverse lights didn't work. Solved one problem, reverse lights now work. But truck still starts in every gear. Looked over past posts but still can't figure out what to adjust. One illustration showed a gauge pin hole, what's that? What do I have to adjust, move, checkout, whatever, to fix my problem? I probably could live with it, am used to it now. Thanks for any help you may have.
Old Nov 13, 2004 | 08:13 PM
Mil1ion's Avatar
Mil1ion
This means to adjust it properly,you need:
1) Transmission in Neutral (chocked wheels)
2) Gear shift lever in Neutral
3) The switch with the holes lined up (use small drill bit to align it).
Once you have done all this......tighten the switch bolts up.
Old Nov 13, 2004 | 11:11 PM
ford390gashog's Avatar
ford390gashog
Smile
those are the best directions to date.
clear and too the point kept up the good work mil1ion
Old Nov 14, 2004 | 04:47 PM
MnBoomer's Avatar
MnBoomer
Excellant instructions. Thanks so much.
Old Jul 21, 2014 | 03:14 AM
Slap2's Avatar
Slap2
Finally after over a week of looking (and learning) this tells me exactly what I needed to know about how to adjust the NSS on my truck. Perfect. Thanks!
Old Jul 21, 2014 | 07:13 PM
mikeo0o0o0's Avatar
mikeo0o0o0
That illustration was taken from the Ford shop manual.
If you want to know anything about these trucks, I highly recommend the factory shop manuals. These are what all the other manuals are based on.
You can find paper copies on e bay all the time. They are also available on CD from several sources.
Chilton and Haynes pale by comparison.
Old Jul 21, 2014 | 07:55 PM
Slap2's Avatar
Slap2
Missed that--
Got the whole set, Mike, but somehow missed that pic. Glad to have attention called to it. Thanks, everyone.
Old Jul 21, 2014 | 08:36 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Old Sep 11, 2014 | 04:13 PM
jbancroft's Avatar
jbancroft
Mike, the factory shop manuals are the ones that come with a separate volume on predelivery set up, maint & lube, right?
Old Sep 11, 2014 | 05:23 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Yup, those are the ones.
martin78
Aug 6, 2025 05:00 PM
MonroeHandyMan
Dec 20, 2014 04:52 AM
Batman7593
17
May 19, 2014 07:30 PM
Mother_Love
1978 - 1996 Big Bronco
Aug 14, 2011 08:56 PM
Dskeet6
Sep 14, 2010 10:29 PM
