6.9 diesel engine seized need help
Old Dec 20, 2023 | 09:45 AM
  #31
scirocc0's Avatar
scirocc0
7th Gear
Haha my kid (16, verrrrrrry interested in this truck) tried a whole lot last night. He was out there freezing his butt off for a few hours getting the injector lines back on and fitting the new return lines. Never have I seen that kid so motivated in the face of adversity and weather!
Took pity after a while and set up a torpedo heater, but didn't remind him to bleed the lines. So it didn't get started, but it cranks nicely and the 120v battery charger is confirmed to work lol. He cracked the lines finally and it's bubbling at the injectors, but we left it there because of time.
I will let it sit until he's back so he can be the one to finally start it, don't wanna take that away from him.
QUESTION: If the cylinders are damaged from the water, what are the likely signs? Just excessive crankcase pressure/blowby? In the even this seems severe, is compression testing useful?
Old Dec 20, 2023 | 10:55 AM
  #32
Olds64's Avatar
Olds64
Depending on the amount of damage to the cylinders you might not be able to start it. If it does start you'll likely have a lot of blowby since the rings and cylinders are both damaged.
A compression test is a good idea regardless of if you can start it or not.
https://www.harborfreight.com/master...kit-57588.html
MNBenny
Sep 28, 2020 09:36 AM
eloham
33
Sep 16, 2018 06:51 PM
kneisl99
13
Nov 14, 2011 12:45 PM
Tom Norton
Jan 28, 2011 09:59 PM
rodymartin
Aug 13, 2008 08:54 PM
