Engine Stumbles
Old Oct 23, 2011 | 04:17 AM
kneisl99's Avatar
kneisl99
Engine Stumbles
My 7.3 has been running pretty good. Of course once started it will restart in a second. And cold starts get better all the time as I make adjustments.
So it was disheartening to have the engine develope a case of the shakes. Its done it twice now. After starting and running nicely for a trip home from work (7 miles) the engine acts like its running on four cylinders for about 30 seconds. This happens when stopping. It appears to accelerate from the condition normally. Then all is well.
Tonite when I get home I will remove the fuel filter and pour whats in it out into a glass jar. I have not been able to figure out how to drain it for water content per the owners manual.
The water in filter light on the dash does not come on when you turn on the ignition.
Is there anything else I should be checking?
Thanks!
Old Oct 23, 2011 | 05:22 AM
Skip1970's Avatar
Skip1970
mine shakes all the time! i dont know what your problem is but i think i need some injectors.
maybe you could run some diesel clean thru ours might have a sticking injector?
Old Oct 23, 2011 | 05:45 AM
kneisl99's Avatar
kneisl99
Ive heard of filling the FF with diesel Kleen and running it.
Does that work?
Really Im hoping its just water or something. The truck runs great when started. If it was injectors wouldnt it run crappy all the time?
Old Oct 23, 2011 | 01:00 PM
hawgystyle's Avatar
hawgystyle
Yes Diesel Kleen does work. Best best is to fill the FF up and start the motor over and turn it off so it can sit in the injectors and injector pump over night. I had a problem where my truck would run great at idle and up to full throttle but once would give it a tap on the pedal and let off or hold the throttle to the floor and let off, the motor would shake and shut off. All problems were fixed the next day after letting the Diesel Kleen sit in the truck. even added to the fuel and it ran better than normal
Old Nov 7, 2011 | 06:57 PM
brif1996's Avatar
brif1996
1995 7.3 psd
what would make a 1995 7.3 psd stumble every once in a while, it only does it on a start up, but it clears up in a few seconds . runs out fine after.. thanks Brian
Old Nov 7, 2011 | 10:27 PM
Aune163rd's Avatar
Aune163rd
your in the wrong forum, this is the pre-powerstroke diesel....but it sounds as if its just having GP issues from a cold cylinder, i would check your glow plugs for wear and tear or them not working...
Old Nov 7, 2011 | 11:03 PM
Ford4Life7.3's Avatar
Ford4Life7.3
Hey brain, here is the link to the powerstroke forums. Come on over and repost your question.
https://www.ford-trucks.com/forums/forum170/
Old Nov 7, 2011 | 11:11 PM
hairyboxnoogle's Avatar
hairyboxnoogle
Some atf or diesel clean will usually sort things out, or at least make it go a while longer. I got into some bad diesel a while back and mine would do the same thing youre describing. Rev it up, let of, stutter, tap the throttle and it was fine. Dropped the filter, put atf in, let it sit in the pump. put some heat and diesel clean in the tank along with fresh fuel and no more problem.
Old Nov 8, 2011 | 11:24 AM
brif1996's Avatar
brif1996
1994.5 - 1997 7.3L Power Stroke Diesel - Ford Truck Enthusiasts Forums
thanks for the help, new to the forum having a hard time navigating...not knowing how or where to post questions.
Old Nov 14, 2011 | 10:34 AM
bankspro6811's Avatar
bankspro6811
is atf and diesel clean just as effective? if so how much would i put in my tank>
Old Nov 14, 2011 | 10:47 AM
86f250XLT-4x4's Avatar
86f250XLT-4x4
If you put ATF in it make sure it is not type F but other than just filling your ff with diesel kleen just follow the recommended dose of it in the tank for ATF in the tank I have heard of people putting 1 quart or more per fill up but be warned ATF makes your fuel appear as if it's red dye and if you are pulled over you can be fined for it!
Old Nov 14, 2011 | 11:38 AM
bankspro6811
oh yeah...i forgot about that stupid red diesel. but thanks!
Old Nov 14, 2011 | 12:45 PM
starmilt's Avatar
starmilt
You need to do as mentioned earlier, remove filter and fill with a good cleaner, lubricant.
I use howes, but diesel kleen, lucas, seafoam and others works as well. start your motor and let it run app 20 seconds, long enough to get straight cleaner in the pump and injectors, then kill it and let it sit overnight. Anytime you have to remove the filter, it is best to do with a warm engine, and I always use a new filter. I would not do this with tranny fluid, as it is sometimes hard to start on tranny fluid and a cold motor.
86f250XLT-4x4
Personally every time I change my ff I fill it with ATF and let it run for about 1 min then let it sit for about 1/2 day and it seems to help ALOT!
Aaron Clowers
15
Jun 3, 2019 10:21 AM
Sabgut
May 18, 2017 01:55 PM
rossistheguy
Apr 13, 2015 12:05 AM
chrisbrady498
Apr 11, 2015 11:41 PM
texas_tech_guy83
Mar 28, 2006 11:29 AM
