6.9 diesel engine seized need help
Old Dec 14, 2021 | 05:12 PM
bulletpruf's Avatar
bulletpruf
Bumping an ANCIENT thread. My 1987 6.9 is said to be stuck. Prior owner bought it as a "ran when parked" truck that had been sitting for years. He never could get it to turn over, so he sold it. He only tried to turn it over using the starter, from what I can tell, and no guarantee that he had 2 good batteries on it, either.
He pulled the injectors and squirted inside with PB Blaster and still no joy.
I've done this before on a gas engine but this is my first time trying it on a diesel, so could use some tips.
What I plan to do is to fill the cylinders via injector cavities with my go-to mix (shot of Kroil, let it sit for an hour, then healthy pour with Marvel Mystery Oil) and let it sit for 24 hours. After that, I plan to try to turn the engine over using a breaker bar on the balancer bolt (looks like it's 15/16").
If it turns over, I'll throw a few hot batteries in it and spin the engine over without injectors to try to get the MMO out of the cylinders. Don't want to hydrolock it.
Is there any advantage to pulling it in 4th gear to un-stick it?
Thanks
Scott
Old Dec 14, 2021 | 05:23 PM
4drocket's Avatar
4drocket
i like ur plan but i doubt u will have room or a big enough breaker bar to turn it so might need to do the 4th gear trick
Old Dec 14, 2021 | 08:56 PM
Prototypemech's Avatar
Prototypemech
I got a marine ford 302 unfrozen by rocking the harmonic balancer bolt with a breaker bar. I got the engine running but it wasnt happy. It had so much blow by, the hull filled up with smoke and the engine would choke itself out on its own smoke. After about 9 hours if operation, I decided it wasnt gunna fix itself so I removed and replaced the whole engine. When I tore down the engine, I didnt find any broken or stuck rings or other smoking guns. Weird.
Old Oct 30, 2023 | 02:44 PM
scirocc0's Avatar
scirocc0
7th Gear
Well, did you ever get it unstuck? Here i am re-re-reviving a long dead, but timeless, thread.
My 6.9 had some clear-as-a-mountain-spring water in the oil pan, a wet intake and a motor that ain't turnin
This advice of oil it and pull on it is all over the place but I don't see too many tales of it actually working...
Old Oct 30, 2023 | 05:27 PM
tjc transport's Avatar
tjc transport
i ain't rite
24 1/2 year old post, and he has not logged on it 14 years.
Old Oct 31, 2023 | 07:12 AM
scirocc0's Avatar
scirocc0
7th Gear
Well, i was aware i was bumping an old thread --- but was actually looking for an update, if any, from @bulletpruf who was having this struggle only two years ago.
And if there's been a good success, have it added to the information in this archeological gem of a thread!
Old Oct 31, 2023 | 07:20 AM
bulletpruf's Avatar
bulletpruf
Here's your update - spoiler alert - it's not good news!
Old Oct 31, 2023 | 08:37 AM
Olds64's Avatar
Olds64
Thanks for posting the video Scott. I'll have to watch some more of your videos to see what became of Project Brutus. Too bad the cylinder was so damaged you couldn't fix her with a hone and re-ring.
Old Oct 31, 2023 | 10:53 AM
bulletpruf's Avatar
bulletpruf
Enjoy the series; lots of trials and tribulations as I tried to find a good engine...
Old Nov 3, 2023 | 05:48 PM
scirocc0's Avatar
scirocc0
7th Gear
Thank you very much for the update!
Is there any chance that this engine can be borescoped/endoscoped? Looking at diagrams of the IDI chamber I'm thinking maybe not.., unless it's extra flexible and extra-small
Old Nov 4, 2023 | 04:25 AM
Olds64's Avatar
Olds64
I've wondered the same thing in the past. I don't think you could get a bore scope through the pre-chamber. Even pouring ATF into the cylinders or spraying it with Kroil/PB Blaster would be slowed down by the pre-chamber.
Old Nov 7, 2023 | 01:49 PM
scirocc0's Avatar
scirocc0
7th Gear
Well, I got the smallest diameter scope i could find on amazon, and it almost worked. The last 1.5" or so of it is inflexible steel, and wasn't able to snake down through the D shaped hole....
This engine was allegedly very recently rebuilt, and the injectors all came out easily (except the one that was missing the copper washer... ) Injectors near the watery-grave corner (firewall, driver side -- is this cyl 5?) had some gross rusty-crusty on, which bodes poorly. A missing injector washer on a "fresh" engine also seems a bad sign --- it wasn't as badly stuck as some, but obviously had been run for some amount of time, and indicates carelessness.
Anyhow, injected ~60cc of ATF into each cyliner, or until filled. I'm pretty confident that most of it made it past the prechambers. Oil pan plug is cracked loose so it will drip, when (or if) and atf makes it to the pan.
Old Nov 8, 2023 | 01:19 PM
  #28
scirocc0's Avatar
scirocc0
7th Gear
oops double post
Old Dec 18, 2023 | 11:26 AM
  #29
scirocc0's Avatar
scirocc0
7th Gear
Well, to follow up ---- we got it unstuck, SUCCESS.
After soaking with PB blaster and ATF (filled the cylinders essentially) for a couple weeks and still no luck pulling on the crank bolt, we dragged it.
Put it in 4th gear and dragged it backwards. Theory that 4th is 1:1 and therefore the most mechanical advantage. Skidded for a few feet and then started chugging.
Now the underhood area is a MESS but that's fine. The idi chamber restricts the stuff blowing out of the cylinders so we put it in reverse (highest engine rpm vs wheel speed) and dragged it a few more times to really blow it all out of there. Also, since the dragging backwards in reverse gear results in the engine turning 'forward' I'm assuming the oil pump was working, and therefore unlikely to cause damage. The rpm are really up there when in reverse at ~15 mph.
Don't forget to disconnect the mechanical fuel pump!
Old Dec 20, 2023 | 07:33 AM
  #30
Olds64's Avatar
Olds64
Excellent!
Are you going to try to get her started?
