remote keyless entry, help!
Old Nov 6, 2004 | 06:26 PM
jeffreyvan's Avatar
jeffreyvan
Angry remote keyless entry, help!
my factory keyless entry just starting acting up
I cannot not lock the doors, either by any of the door lock switches or the remote keyless entry, however I can unlock with either or. I found the fuse, it was not blown (because I can unlock the doors) when I removed the fuse and put it back in, the doors locked automatically. I then tried the door switch & remote, it still won't lock. I repeated removing and installing the fuse several times, each time I put the fuse in, the doors locked by themselves. I thought maybe if if disconnected the battery, I did but no change. I must be the RKE module, the door locks do work when the fuse is replaced but just once. This happened once before it lasted several weeks and went away, any ideas ?
Old Nov 7, 2004 | 02:18 PM
prcrboy's Avatar
prcrboy
If its with door and remote, then your probally on the right track.
Greatcarsx4
Nov 30, 2014 10:59 PM
AndeyHall
Jul 29, 2013 04:57 PM
ExpySport
Oct 22, 2008 07:40 PM
jjs2032
Apr 22, 2008 08:27 AM
waldreps
Dec 23, 2006 09:50 AM
