'98 4.6 Windsor startup noise
Yes, i have spent HOURS reading all the posts about this issue!!, but mine has gotten worse lately. '98 F150 150k miles. I've owned for 50k miles and has always made the startup noise that i would guess is PS. I use castrol oil and motorcraft filters.
Mine lasts only about 2 seconds at startup, but sounds really loud lately and different than a knock or dry lifters noise. Since it is always worse when it is cold, i am guessing it still must be the PS issue, just getting worse.??? Could someone please describe what their PS sounds like and does anyone elses go away this fast?
If it is the timing chain tensioners, is it ok to just ignore it?
I just tried switching to Mobil 1, and will see tomorrow morning if it helps at all.
Thanks for all the info on this issue.
Originally Posted by mower
just bought it with 60000kms, mint truck, but when truck is cold when started it has this awfull noise for about 1-2 seconds, then its fine, no other problems, got 5w30 oil in it , any ideas?
Whimsey
all fixed!!!! sorry but oil filter didnt do anything so i took it to ford and told them everything about this start up noise, and they started it up the next morning, and told me its the starter, i just said fix it, 400 bucks later, problem gone, i'm happy it could have been alot worse (PS). they said it was a worn out appendix on the starter assembly. good enought for me, whimsey thanks for the info anyway.
640 CI Aluminum FORD
2009 - 2014 F150
08-09-2011 05:47 PM
