Odd noise from engine area until warm.
Old Sep 23, 2011 | 12:25 PM
TYZ78F150's Avatar
TYZ78F150
2004 X 5.4 86K on the ticker.
Noise has been getting worse. After it is started, it makes sort of a squeal/rattle noise. It gets worse as I press the gas. It is a cross between a P/S pump going out and an exhaust rattle. Now, the noise doesn't get worse when I turn the wheels back and forth, so I'm leaning away from that.
I know it sounds a little vague, but it is a hard noise to describe. I'm hoping it's not my tranny going out. It shifts fine and was flushed about 12K ago with synthetic fluid.It goes completely away once the truck is completely hot though.
Old Sep 23, 2011 | 01:50 PM
jasoncw's Avatar
jasoncw
When idling, does the noise change with RPMs? I am going to guess one of the pulleys' bearings is going bad. You could try removing the belt and feeling if any of the pulleys do not rotate freely to try to narrow it down.
Old Sep 23, 2011 | 08:44 PM
TYZ78F150's Avatar
TYZ78F150
It stays steady until I give it gas, then it gets louder. I bought a new belt to put on it, couldn't I remove the belt and start it and let it run for just a minute or so to hear for the noise?
Old Sep 25, 2011 | 08:00 AM
Catatonic 515's Avatar
Catatonic 515
I had the same problem......it was a loud squeal/exhaust leak noise. It was the exhaust manifold gaskets/studs.
I wopuld never have thought it would make the squealing noise but it did.
Old Sep 26, 2011 | 02:55 PM
BassFantasizer's Avatar
BassFantasizer
The good news is that since it's a noise, an exhaust leak should be easy to verify.
It also sounds like it could be an issue within the EGR system. Also should be fairly easy to isolate or discount.
CityGuy24
6.4L Power Stroke Diesel
Feb 27, 2010 07:43 AM
hi-jacker
Nov 25, 2006 07:38 AM
Andywk
Dec 8, 2005 07:12 PM
TheDuke
Jun 6, 2005 05:50 AM
MemOrex
Sep 14, 2004 09:16 PM
