Rear end Clunk/Pop?
Old Oct 24, 2004 | 03:13 PM
jbone108's Avatar
jbone108
Rear end Clunk/Pop?
my rear has made a loud clunking sound twice now in the past 2 days. first time I was taking off at a light and it was real loud I tought the tranny was going to fall out. then today I was driving in my pasture and had gotten stuck on a hill I stopped put it in 4whl drive and it clunked again not as loud. could this be coming from the L.S. releasing or catching?
Any ideas?
thanks...
Old Oct 24, 2004 | 05:04 PM
sbarlow's Avatar
sbarlow
jbone sounds like one of you universals is going bad. 1 Hour fix if your out of warranty.
Old Oct 24, 2004 | 06:23 PM
YOMAN's Avatar
YOMAN
YEah it sounds like u-joints in driveshafts. Go under the truck and play with driveshaft w/ your hands and try to rotate, shake up/down while your at it, listen or If theres some play in there then its u joints.
YOMAN!
Old Oct 24, 2004 | 06:49 PM
jbone108's Avatar
jbone108
I am waiting on a driveshaft now "for the vibration problem" should be in this week. the truck only has 2300 miles on it!! u-joints that quick????
Old Oct 24, 2004 | 06:51 PM
YOMAN's Avatar
YOMAN
I can replace PER u joints for about 10 min.
YOMAN!
Old Oct 25, 2004 | 08:05 PM
Kurious's Avatar
Kurious
Jbone, sounds like it could be the clutch packs in your rear-end...
Old Oct 25, 2004 | 08:06 PM
jbone108's Avatar
jbone108
it has not done it sense sat. I think it's something todo with the L.S. rear in the truck
Old Oct 25, 2004 | 08:13 PM
scottie2hottie's Avatar
scottie2hottie
I've blown brand new spicer u-joints in the first trip out. Maybe that has a lot to do with the 600 hp big block and 38 inch tires.....but anyway I would say your noise is in the clutch packs of the Limited Slip...
Scott
Old Nov 7, 2004 | 06:46 PM
Fcal's Avatar
Fcal
Had the clutch packs changed about 2 months ago, my driveshaft greased twice, and now there seems to be a new problem. Sounds alot like yours Jbone. When I'm going slow over rough ground, sometimes when I step on the gas, it feels like someone hit me in the rear. It seems like the rear is slipping and then catches. I'm hoping it's not the tranny. Seems more like the rear end.
Primerranger
Mar 12, 2015 06:11 PM
Nick Greer
Aug 6, 2012 10:19 PM
7.3lpowerstroke
Oct 22, 2011 01:00 PM
mrl390
Sep 22, 2006 10:04 PM
bearbronco
1978 - 1996 Big Bronco
Nov 28, 2001 07:27 PM
