My 73 F100, 390, C6 transmission has a loud clunk going into reverse. When I move from reverse to any forward drive gear, the noise is almost not there...Any ideas what could be causing this noise, and if it's anything to worry about?
i have a 77 f100 with a 302 and c6, and it does the exact same thing, sometimes only when i put it into reverse and hit the gas right after, but doesnt do it on any other gear whatsoever
Check the U-joints but it could also be excessive backlash in the rear....U-joints, if bad replace. Excess backlash, I wouldn't worry too much about it.
oh haha i guess it didnt write it, but its because when i put my donor rear end i bought new u joints, because i had to change them because of the driveshaft, long story short, they're brand new
Mine does the same thing, and i know for a fact its not a u-joint problem( just replaced them)
I have to agree its a backlash problem to, matter of fact my rear end makes noises now after changing the both rear outer axle seals and bearings and adding new fluid with the trac lock additive.
Backlash is the clearance between the ring and pinion in the differential. Usually it's a few thousandths of an inch but years, mileage, abuse, etc. cause it to increase allowing the pinion to "bang" when put into gear.
Like I said, not something I would really worry about.
I've owned 2 of these trucks with automatics and both made the same clunk going to reverse and this when they weren't that old. I've heard many others all make the same noise, all automatics.
I've drove many of these trucks with automatics and I believe part of the problem along with to much backlash is that they engage to hard into reverse to begin with.
I'm inclined to agree, I have often thought it must be something inherent to the C-6
