brakes clunk
Old Oct 18, 2011 | 09:09 PM
7.3lpowerstroke's Avatar
7.3lpowerstroke
brakes clunk
When I push my brake pedal in my brakes make a loud clunk sound. If I use my brakes not long after they made the clunk sound they don't make the sound but if I drive a while then use them again they make a clunk sound. I'm thinking it might be a caliber the brakes work fine to. Any help would be appreciated
Old Oct 18, 2011 | 09:52 PM
bashby's Avatar
bashby
Listen and try to figure out where the noise is coming from... under the dash, RR, LF... maybe roll the window down and hang your head out of the window and try to duplicate the noise.
Old Oct 19, 2011 | 05:54 PM
7.3lpowerstroke
It sounds like its coming from the front I can't tell which side thow.
Old Oct 19, 2011 | 09:20 PM
f-trucker88's Avatar
f-trucker88
check youre sliders and if your rotors are heavily grooved they could be pushing the caliper up and then it pops back in place with the pressure nothing better than a good thorough visual inspection
Old Oct 19, 2011 | 10:30 PM
GoinBoarding's Avatar
GoinBoarding
Trailing arm bushings!
Maybe not in your case, but when my trailing arm bushings were wore out this is exactly what they did.
Old Oct 22, 2011 | 10:47 AM
7.3lpowerstroke
Is a radius arm the same as a trailing arm
Old Oct 22, 2011 | 11:09 AM
bashby's Avatar
bashby
yes........
Old Oct 22, 2011 | 01:00 PM
hoss khaos's Avatar
hoss khaos
Mine did the same thing and I found out the springs on my rear brake shoes were worn. I could of swore it was coming from the front but I found out it's from the back. They also could be needing adjustment.
sawtooth
6.4L Power Stroke Diesel
Sep 24, 2012 01:54 PM
jck_strw
Nov 18, 2008 12:02 AM
cadriver
1983 - 2012 Ranger & B-Series
May 4, 2007 05:14 PM
jrb93Ranger
Sep 20, 2004 03:54 PM
seebeew
May 30, 2002 01:56 PM
