rear main seal stuck
Today I embarked on a jurney that was soposed to be quick and simple. I went to pull the rear main seal by droping the pan (tranny is already off I figured I do the seal at the same time as a clutch job.) I then pulled the oil pump, droped the crank about 1/32" like your soposed to , pulled the rear bearing cap and stuck a screw in the upper seal. I used a screw about an inch long and griped it with pliers and beat down on the pliers. Unfortunatly I only pulled out about two inches of the seal and now I'm not sure of the easiest way to get the rest of the seal out. This is for a 400 by the way. Any answers?
thatdarncat
05-19-2017 07:02 AM
PapaBearYuma
10-27-2016 01:53 PM
Friesian-Bronco
08-23-2010 07:01 PM
jim4
15
12-26-2008 03:03 PM
