best compression
Old Oct 12, 2004 | 07:52 PM
CoachRobb's Avatar
CoachRobb
best compression
what is the best compression for a 30 over 351m. i will be using a comp cams 255 or 265 deh cam. its a complete rebuild give me your ideas. thanks in advance. robbin
Old Oct 12, 2004 | 08:21 PM
danlee's Avatar
danlee
With a 255DEH, you could use 9.0:1. With a 265DEH 9.5:1 should be OK.
The problem that you have is getting those CRs. Stock pistons are about 8.0:1. There is a TRW piston that gets up to about 8.5:1. You can use Aussie heads with the 8.0:1 pistons and either cam, but you will need more cam than the 265DEH to use Aussie heads with the higher CR pistons.
79FordBlake
30
Jan 9, 2014 07:18 PM
4drf350
1966 - 1977 Early Broncos
Mar 19, 2012 02:22 PM
blueovalboy_69
May 2, 2008 01:22 AM
76 F150 Ranger XLT
Mar 5, 2004 05:01 PM
nitrous125
Nov 22, 2001 09:18 AM
